BRP/SOT Hotside SC Install
Old Mar 5, 2008 | 03:35 PM
  #471
UberDuper's Avatar
DynoComp
Good numbers on that dyno. Did you have dynocomp tune?
UD.
Old Mar 6, 2008 | 05:46 AM
  #472
vader1's Avatar
Wlaurent,
What is involved in the intercooler system. Since it involves water, I assume there is a pump installed somewhere. No? Maybe you could expalian that a little.
And anyone know where you access the fuel pump? And do high flow Walbro's last as long as stock models, say 100,000 miles or so?
I think I would have a mechanic replace the pulley for me, but I think the rest seems like something I could do in the garage unless you have to drop the whole fuel tank, but I am going to have to get dirty anyway and do my oil jet bolts.
Old Mar 6, 2008 | 05:59 AM
  #473
camuman's Avatar
Originally Posted by vader1,Mar 6 2008, 09:46 AM
Wlaurent,
there will be a small pump to move the water/coolant for hte air to water intercooler as well as an exchanger mounted in the bumper. very easy to install.
to swap the pulley you just use a pulley puller, also very easy. trust me if you can change oil jet bolts, then you can do the pulley.
Old Mar 6, 2008 | 07:01 AM
  #474
vader1's Avatar
Electric pump then for intercooler?
Old Mar 6, 2008 | 08:03 AM
  #475
neptuner's Avatar
Yes, it is a small electric pump. Here is a picture of mine. The pump is the black cylinder with the 2 white wires connected that is mounted on the floor between the intercooler radiator and the main radiator.
Looking down on pump for the intercooler radiator.
Old Mar 6, 2008 | 08:06 AM
  #476
GRUNTS2K's Avatar
So how many of these test mules are out there?
Old Mar 7, 2008 | 07:23 AM
  #477
WLAURENT's Avatar
Originally Posted by GRUNTS2K,Mar 5 2008, 03:18 PM
What are your other mods Wlaurent?
At time of that dyno I was running a BB Tri-Flo cat back. Now I am running a test pipe. Other than that - pretty much all stock.
Tune was my conservative tune - just popped into dynocomp to see what kind of power it was putting down.
There are 4 cars running the kit currently
Old Mar 7, 2008 | 03:02 PM
  #478
y4ngel's Avatar
From what I understand, you are on your stock rear diff and stock clutch?
How is that holding up for ya
Old Mar 7, 2008 | 04:52 PM
  #479
EssToOfouzEn's Avatar
Just found this thread today and read all of it!!! holly wow that took a long time LOL. i like the kit, but too many things to re-locate and if im correct ECU solution is still an issue....and it whines! haha. in comparision to kraftwerks, which is a Rotrex not a centrifugal, the TQ curve on the SOT is amazingly better at low end. but the HP curve look good in both kits. as far as an option for the 06+ i didnt see anything stating the SOT kit being availible for DBW's AND I live in cali and would hope for somehting to be carb legal. KW is carb pending as we speak.
So my question is will this kit be availible for 06+ and are they gonna do anything about carb legalizing it? Thank you.
Old Mar 10, 2008 | 07:57 AM
  #480
WLAURENT's Avatar
My clutch and diff are holding fine - of course I am no drag racing or 18 any longer.
