Built F20c into 07 AP2 w/ DBW
Old May 17, 2017 | 08:48 PM
drifts2's Avatar
Unhappy Built F20c into 07 AP2
I bought a fully built F20c which I plan to run boost on. Its an f20c Block with AP1 head.
I plan to replace my blown f22 on my 07 ap2, I was wondering what do I exactly need to do to run the f20 on my car.
Besides change the Intake Manifold/TB/fuel rail/injectors etc to run ap2 Harness.
Do I need to change Cams and Crank Trigger Wheels or can I keep the ap1 and just put my cam sensor.
Ill be using Hondata Pro To tune the Vehicle.
Thanks,
Brayan
Old May 18, 2017 | 01:41 AM
ajohnson's Avatar
I think you need to change crank sensor, crank trigger wheel, exhaust cam trigger wheel and sensor and use the late valve cover
Old May 18, 2017 | 03:08 AM
Chuck S's Avatar
Hondata Pro? K-Pro? Are you retaining the 2007 DBW ECU?
-- Chuck
Old May 18, 2017 | 04:27 AM
afzan's Avatar
Originally Posted by ajohnson
I think you need to change crank sensor, crank trigger wheel, exhaust can trigger wheel and sensor anduse the latevalve cover
Yup. And the Intake manifold, TB and fuel as mentioned by OP.
You'll also need to block off the air pump passages near the exhaust ports on the head
Old May 18, 2017 | 07:35 AM
drifts2's Avatar
-- Chuck
It will be Hondata FlashPro,Yes I do still plan to Retain the 07 DBW Ecu, should be possible correct?
Old May 18, 2017 | 07:41 AM
drifts2's Avatar
What air pump passages exactly, is there anyway to get a picture ? After all of this is done I can bolt on my turbo kit like normal and tune it and everything should run right correct?
Or is there other problems im going to run into ?
S2Killl
Dec 30, 2016 01:53 AM
liquidgsr
Oct 21, 2014 04:00 AM
liquid_helix136
Aug 20, 2014 06:22 PM
AWWHITE s2k
Sep 22, 2013 06:05 PM
super2k
Nov 11, 2011 03:33 PM
