Bunch of Question
Old Oct 5, 2005 | 05:52 PM
  #21
Slows2k's Avatar
The cooling system isn't holding pressure. Possible coolant leak somewhere. If you have no visble leaks, A blown headgasket can cause this.
Old Oct 5, 2005 | 09:27 PM
  #22
Partshelper's Avatar
good to know. Now I just gotta get a leak down, if it is the head gasket . that mother *#@ is coming off this weekend. and I will be back on the road once again. . If not I will be screwed.
Old Oct 7, 2005 | 12:31 PM
  #23
OK So I got it tested yesterday, and it is the head gasket again. I got my new head gasket shipped from Cometic today along with the head bolts from ARP. Wondering what torque to do on the Head Bolts?
Old Oct 9, 2005 | 10:46 PM
  #24
thanks for all the help guys, got the problem fixed, it was the head gasket, also got the head milled a little bit while it was off. Used the ARP head studs/ Bolts. Car runs great, not loosing anymore water. WOOO HOO.
Old Oct 30, 2005 | 11:20 AM
  #25
Asura's Avatar
Not sure if this is related, but I was looking at the banjo fitting for the BDL fuel rail in comparison to the OEM banjo for the fuel dampener.
The OEM one has a hole going through the center bore.
The BDL supplied one has two holes at 180 degrees to each other going perpendicular to the length of the bolt. I an wondering if this has an effect when the car is turned off/on.
Greg- are you using the AEM 3.5 bar map or the GM 3 bar?
Walnut
Nov 11, 2012 06:05 PM
volkdc2
May 10, 2012 10:06 PM
batikan
May 16, 2007 06:56 PM
s2kjb
Nov 16, 2006 07:06 PM
facets
Jan 22, 2004 08:21 AM
