Buying Used Comptech Help!
Old Feb 26, 2010 | 04:44 PM
rsxiness03's Avatar
Default Buying Used Comptech Help!
Hey guys a good friend of mine is supercharging his car and going to be picking up this kit..Took pictures of everything that is there..Please help me im trying to figure out if there are any parts i'm missing..
Oh he mentioned the crank pulley is not there and i will need to ship my current crank pulley to comptech (with a core charge of $400). Other than this part anything else
Your help is greatly appreciated
Thank you
http://img.photobucket.com/albums/v417/hen...le/P1030542.jpg
http://img.photobucket.com/albums/v417/hen...le/P1030541.jpg
http://img.photobucket.com/albums/v417/hen...le/P1030527.jpg
http://img.photobucket.com/albums/v417/hen...le/P1030543.jpg
Old Feb 26, 2010 | 05:41 PM
Moddiction's Avatar
Former Sponsor
Don't see a fuel pump. That's $100 for one new.
Old Feb 26, 2010 | 05:45 PM
rsxiness03's Avatar
Sorry yea I'm aware of fuel pump as well most used kits don't come with that.. I'm more worried about bolts brackets and other little things I might not know about.. Thank you tho
Old Feb 26, 2010 | 05:55 PM
Moddiction's Avatar
Former Sponsor
Yeah don't know about the rest.
I bought a partial vortech kit and pieced that together recently but they are definitely a good bit different.
Isn't there a parts list or install manual you can look through to see? That's how I was able to order everything up that I was missing.
How much that kit going for?
Old Feb 26, 2010 | 06:36 PM
s2k aok's Avatar
Old Feb 26, 2010 | 06:48 PM
rsxiness03's Avatar
Thnx soo much dude pm me on how to do that was trying to figure it out
Old Feb 26, 2010 | 11:07 PM
jaundice's Avatar
Missing lots of bolts... All metric and can be purchased at hardware store or Fastenal. You really need a copy of the install instructions for all bolt sizes. Looks like all brackets and pulleys are there. Will need fuel pump and S/C crank pulley. Will also need modified S2000 crank pulley that will allow you to bolt the S/C crank pulley (missing) to it.
I sold my S/C with install instructions to another member. He may be willing to copy them for you. PM me and I will give you his info.
Old Feb 27, 2010 | 06:03 AM
rsxiness03's Avatar
I understand I need the modified crank pulley with 6 holes..but I'm missing the supercharger pulley as well?? Damn I thought he said supercharger pulley for stock boost was there
Old Feb 27, 2010 | 07:50 AM
s2k aok's Avatar
yeah you need the modified stock crank pulley but i don't see the supercharger pulley that bolts to the modified stock crank pulley, the boost level is determined by the size of the pulley on the backside of the bracket that supercharger unit is mounted to but you need the bolt on pulley attached to the crank pulley to spin the supercharger's pulley.
here's the pulley you'll need (comparison of oem and modified oem plus bolt on pulley)...
edit: top = leftside bolt on pulley, rightside is modified crank, bottom = oem crank
Old Feb 27, 2010 | 07:55 AM
s2k aok's Avatar
comptech/ct-engineering home site:
http://ct-engineering.com/
go to tech install and select the parts list and aftercooler parts list, a pdf should pop up that shows the parts/part numbers if you gotta order.
