Calling InlinePro bros
Old Aug 17, 2006 | 05:49 AM
GDM S2K's Avatar
Hey Mathew Sham called me about the heat issue. im waiting on the sock from boost logic for my car. he wanted to use it on yuor car as well when it comes in ill give u a ring and u can check it out
Old Aug 17, 2006 | 05:58 AM
OGPackin's Avatar
Cool, id like to pick one up JIC. Can you order me one too?
Old Aug 17, 2006 | 06:00 AM
GDM S2K's Avatar
We have like 5 on order, the problem is there hand made and take a long ass time to get done im going to call this afternoon about them I should be running in 2-2.5 weeks so im going to need it!
Old Aug 17, 2006 | 06:03 AM
OGPackin's Avatar
Nice! Im sure your getting excited!
Are all 5 spoken for? Can you put one aside for me?
Old Aug 17, 2006 | 06:07 AM
GDM S2K's Avatar
3 are spoken for ill def have one on the side for you, after all you did give me a ride in the beast
Old Aug 17, 2006 | 06:11 AM
OGPackin's Avatar
Sweet thxs a lot!
Old Aug 17, 2006 | 06:46 AM
geists2k's Avatar
Originally Posted by OGPackin,Aug 16 2006, 06:33 PM
Hey guys! Nothing major, but i thought id share some issues that have come up due to heat.....Some of you know iv had my car in the shop. While there my mechanic noticed my fuse box was melting due to the heat coming from the turbo. Also he found the motor mount right below the turbo was shot. He fabbed a heat shield for the motor mount and wrapped it with a heat wrap. I also bought a ARC fuse box heat shield. Id recommend both to avoid a similar problem.
Ya and InlinePRO -- any comments about this?
Old Aug 17, 2006 | 07:41 AM
CourageOO7's Avatar
Originally Posted by CaptKirk,Aug 16 2006, 11:19 PM
Hmmm good idea, thanks
Would an engine torque brace make the ride harsher? Meaning, will the car vibrate and shake more when the motor is running?
Yeah, you'll get a little more driveline vibration but it's worth it. I had one in my FD and it actually helped during very hard acceleration shifts. The engine wouldn't turn over so the tranny would remain planted and it helped with missed shifts and that kind of nonsense. It's a more economical solution. Besides, you have a turbo S2000...a little driveline vibration makes it feel racier!
Old Aug 17, 2006 | 08:12 AM
ya@inlinepro's Avatar
As far as the fuse box melting, we haven't seen that problem on our street car. This is the first incident, maybe we can try to create something similar to the ARC box.
As far as the mounts concerned, If you had a stock s2k on the lift, you can literally rock the motor with your hands. The engine mounts on the s2k are really soft and liquid filled. I'm sure heat has a lot to do with the mounts being ruined, but also when you add that much torque and shift hard, i'm sure that hurts the s2k mounts a lot.
We are in the middle of designing motor mounts for the s2k, hopefully later this year?
Old Aug 17, 2006 | 09:59 AM
kenyellows2k's Avatar
ya good idea, if you guys can come up with something I am definately interested. I will call you guys soon for some tuning, I was there before to put my ACT clutch.
