Can ID 1000's reach 500hp on e85?
#22
I am in the same scenario with my ID1000 and Walbro 485.
SOS SC with 3" belt making 15.5-16 psi
ID 1000
Walbro 485
AEM FPR with base pressure of 45 psi.
Car is a 08 with AEM EMS V2 and running E85 and a SOS return fuel system
Currently after 7500 RPM. I am running out of fuel with injector duty cycle around 90% and after 8000 rpm i am seeing 100% duty cycle.
Either A i get some 1300 or just up my fuel pressure to 60-65 psi which would rate my ID for 1200-1250 cc which is good for what i'm after. I just can't justify going 1300cc with the price increase especially for my application. For the turbo guys it would make more sense.
With my case it is a SC application and would only require that fuel after 7500 RPM.
I will report back once I get my map adjusted for my extra fuel pressure.
E85 is great also! helps with the black soot on the bumper and smells a lot better then pump gas that is for sure.
ID 1000
Walbro 485
#23
Id1700x
On ID1700 what base pressure are you running them on without random misfiring? Im working with 50psi base and my deadtime is 3.05, 1.83, 1.32, 1.02, .83.
#24
Well why is it misfiring? Too much fuel? Lower the base pressure is the first step. The lower the total fuel mass being injected the better if you are fighting a rich condition.
