Car last night started running lean as hell
Originally Posted by o'malley_808,Apr 2 2009, 09:07 PM
When did you just do the tranny service?
Check your essentials first being check the battery voltage. Not sure if you have access to tools and what not but there is a wire going to your starter and its a female connecor with a black rubber boot around it on the starter motor closest to the front of the car. (Starter motor is buried under the throttle body right where the engine meets the transmission. This wire is a PITA to get to but it is the trigger to your starter to start so check that this didnt fall off because it is a royal pain in the butt to install so it could have been partially seated as it has to come off to remove the starter when removing the tranny.
Worst comes and your sure that everything else on your car is fine and mechanically sound you could get a few friends to get you to try bump starting the car at least to get it to your shop....
Originally Posted by REVHIR,Apr 4 2009, 03:16 PM
BTW I did find a wire right by the alternator that is well unplugged. But it looks like its been pulled; torn off the socket and belongs somewear... hmmmm....
tommylam16
Jan 3, 2010 02:22 PM
