car overheating
Old Sep 22, 2011 | 09:52 PM
Batbite's Avatar
Originally Posted by *JG*
My kpro does the same exact thing, I think all of them do it. As far as bleeding the system let the car get warm(feel the top radiator hose and once it gets fairly warm) crack your bleeder on top of the intake manifold where it bolts to the head. Then you should see the air come out. I just crack it a little and let the air run itself out.
yup.....ya gotta burp the system to get out all the air pockets....if you do this correctly the overheating issue should minimize, if not go away all together. make sure to fill your overflow tank up some before you burp the system....it is likely that it will intake some fluid from the overflow tank to compensate.
Old Sep 22, 2011 | 11:58 PM
riceball777's Avatar
my aem series 2 does the same thing. It does not run the stock temp gauge correctely and is very glitchie. I have a serial gauge which reads the waters temps and my car does not over heat.
Old Sep 24, 2011 | 07:08 AM
Round 3's Avatar
get a serial gauge or data log it on the laptop. My stock gauge did the same thing when I had the AEM V2 in there as well. Same symptoms you had. checked it with the laptop and everything was fine.
Old Sep 24, 2011 | 06:06 PM
HMFIC's Avatar
I have an Aem series 2 and i dont any of those issues.
My car was properly bled. That may be your issue.
ryanvnw
Aug 11, 2016 09:31 AM
hatchsiturbo
Apr 24, 2016 09:07 AM
DogBiscuit
May 28, 2015 10:50 AM
Bigpeters2k
Aug 17, 2011 09:22 AM
siadam
May 11, 2009 12:18 PM
