CEL problem
Old Apr 6, 2008 | 02:08 PM
brilliant's Avatar
Default CEL problem
Hey everyone,
So basically, I have a CEL issue and am trying to figure out the source of the problem.
The CEL only comes on when i'm on the freeway, just cruising, and even in neutral. It'll just come on randomly, and stay on. It is weird because it only comes on while i'm driving on the freeway, maybe something about higher speeds triggers it? Also, when I reset it, it will stay off when I'm driving around town, even if i go WOT it does not come on. In fact, todd at Church's reset it and it stayed off the whole tuning session.
Anyways, not sure if it is my Invidia test pipe or not. I would think that if it were the test pipe, the CEL would come on all the time. Any inputs on what it might be will help. Mods are in sig.
Thanks!
Old Apr 6, 2008 | 02:13 PM
RISLAR's Avatar
Did you get the code number?
Old Apr 6, 2008 | 02:28 PM
brilliant's Avatar
i'll get the code and post it ASAP.
Old Apr 6, 2008 | 02:36 PM
RISLAR's Avatar
I would as you can never be to carefull, its prob that the decat needs a antiplug fowler, but you'd better check first
Old Apr 10, 2008 | 08:09 PM
brilliant's Avatar
just got back from autozone, the code i'm getting is P0420. any ideas?
Old Apr 10, 2008 | 08:15 PM
Enthralled's Avatar
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
my guess is a test pipe problem or your CAT if you still have it.
Old Apr 10, 2008 | 09:33 PM
brilliant's Avatar
ok thanks
Old Apr 10, 2008 | 09:46 PM
Mr.Aqua's Avatar
Yep I get the same code from my TP with a so called CEL fix on it. I need the anti fouler adapter.
Old Apr 11, 2008 | 01:58 AM
brilliant's Avatar
where would i purchase it?
Old Apr 11, 2008 | 03:57 AM
brilliant's Avatar
ignore that question. i'm good
diaz8645
Feb 16, 2010 02:49 PM
Requiem
Feb 10, 2010 06:43 PM
RaRa gizz
Aug 5, 2009 09:42 AM
Hamburglar
Oct 22, 2008 11:05 AM
S_NeWb
Aug 27, 2008 08:07 AM
