Charge Piping Behind Headlight Question
Old Sep 1, 2013 | 05:57 PM
tx2K's Avatar
Default Charge Piping Behind Headlight Question
Does anyone have any pics of their 3" charge piping running behind their headlight where the bracket that needs trimming is? Im trying to figure out what exactly needs to be trimmed. I have some misc stuff laying around to use for it so I wont have to spend any money, except for a couple of clamps. Since I have so little room to run the common RU-2510 filter, I want to run an actual 3" intake in there and use the bigger filter I have. Thanks for any help
Old Sep 1, 2013 | 06:51 PM
herecomesboost's Avatar
You can simply remove the support bracket if you'd like.
Old Sep 1, 2013 | 07:11 PM
tx2K's Avatar
If I remove that will my headlight bounce around or have any problems?
Old Sep 2, 2013 | 08:15 AM
vduber's Avatar
Nope I removed that bracket for my trackforged kit aswell by time you trim the bracket theres not much left might aswell remove it and no it has no negative effects
Old Sep 2, 2013 | 09:08 AM
tx2K's Avatar
Okay, thanks for the help guys. Ill give it a go
Old Sep 2, 2013 | 02:11 PM
bobbyrandolph440's Avatar
Any pics of that way
Sent from my VS870 4G using Tapatalk 2
Old Sep 2, 2013 | 02:12 PM
Old Sep 2, 2013 | 03:01 PM
riceball777's Avatar
I have my 2.5 inch intercooler piping routed this way. 3 inch should fit too. I also removed the headlight support bracket with out any problems.
The benefit of doing this is that you do not need to run slim fans and the stock fans fit fine. But you will have to relocate your coolent bottle.
tobyCHIPPO
Jun 3, 2013 07:03 AM
DISCONTD
Mar 26, 2012 11:39 PM
albe
Oct 16, 2007 12:59 PM
photown
May 27, 2007 11:26 PM
yelloS2
Sep 3, 2003 06:13 PM
