Chefs NEW Kraftwerks problem
Old Jul 29, 2015 | 01:36 PM
  #101
LBPS2K06's Avatar
I am running a Mishimoto with Mishi fans and shroud. Have had no problems with overheating. As matter of fact, the fans did not kick on until weather got into the mid 60s.
Old Jul 29, 2015 | 01:52 PM
  #102
chefs2000's Avatar
ok I guess it ain't the rad.. Thanks for input.. Bled it and no air ... Drove it and it drives fine in traffic and hwy without ac as soon as i turn ac on it takes 2 min to over heat .. I turn it off and it goes back down ... So I'm clueless right now kraftwerks said no one is havin that problem .. But did offer to send me tubing if I need to relocate the oil cooler for the kit.. Incase that is blockin air flow .. I'm ready to cut my hood up a little bit .. But I would like to solve this problem .. Hopefully by next week I can hook it up to get the engine temp from the computer and see what the temp is actually goin to ...
Old Jul 29, 2015 | 02:10 PM
  #103
benb's Avatar
Other threads about overheating due to the blockage caused by the addition of the KW oil cooler and intercooler. My car did same things with original KW kit. Had to add extreme SPAL 12" fans to combat the Texas heat. Just my .02
Old Jul 29, 2015 | 02:16 PM
  #104
chefs2000's Avatar
wonder if they modified it since .. Where's the oil cooler located on yours ?
Old Jul 29, 2015 | 02:43 PM
  #105
Habitforming's Avatar
Originally Posted by chefs2000
Any one take oil temp at idle after running for a little bit? I took the temp of my rotrex can and it was at like 240 with car at normal temp
240 is awfully high, these temp issues may be the reason for your blower troubles. The question is, why the temp issues? This is from the Rotrex technical handbook, page 17:
ensure that oil temperature at the inlet of the supercharger never exceeds 80°C (176°F) as higher inlet oil temperature will damage the supercharger.
Old Jul 29, 2015 | 03:02 PM
  #106
chefs2000's Avatar
tested it when I went out and it was around 160 at inlet
Old Jul 29, 2015 | 06:30 PM
  #107
shiv's Avatar
Hey Chef, just caught up on your situation. Glad to hear your car is up and running after your ordeal. Crazy how much has happened since the Glen. But congrats on the Si purchase. Let me know if you decide on rocking another track day this year, I'll try to make it out as well. Also are you running stock fan switch/thermostat right now? Keep posted on how the kit is working.
Old Jul 29, 2015 | 07:02 PM
  #108
so then what was 240? I'm confused.
Old Jul 30, 2015 | 04:07 AM
  #109
chefs2000's Avatar
hey brother hopefully I make it to that safety track day on August 24 ... Yes stock fan and thermostat .. I still owe u a whiskey !
Old Jul 30, 2015 | 04:11 AM
  #110
chefs2000's Avatar
I shot the outside of can with the infrared .. It was 240... The 160 came from the hose on the inlet .. I have a digital thermometer from work that I will drop right into the can to get the exact temp of the oil .. I need to do a little more testing.. I want to get temps after running it hard and also on street driving .. Kraftwerks said the can could just be pickin up heat from the engine .
