Chefs NEW Kraftwerks problem
I'm glad you are up and running again.
I also have no issues with the A/C on in traffic at 90+ degrees. I have the stock cooling system with an oil cooler. The KW supercharger did not affect the coolant temperatures in traffic.
Any one running after market radiator ? I will try to bleed when I go home and check it if it's low .. If not may go back to stock radiator .. My mechanic said it maybe to large for the water pump to keep the correct flow .. Just a thought
It must just be not properly bled, that's about the only thing that would make sense.
Are you going by just the bars on the dash, or do you have a serial gauge or datalog with the specific coolant temps you were hitting? it's possible it just isn't displaying correctly on the dash, but i thought the AEM V2 had that corrected for our cars.
Originally Posted by Habitforming
<img src=/iagree.gif' class='bbc_emoticon' alt='
' />' /> It must just be not properly bled, that's about the only thing that would make sense. Are you going by just the bars on the dash, or do you have a serial gauge or datalog with the specific coolant temps you were hitting? it's possible it just isn't displaying correctly on the dash, but i thought the AEM V2 had that corrected for our cars.
Originally Posted by wadzii
what brand is the radiator? I've seen cheap Chinese aluminum radiators cause problems but never quality name brand stuff
