Clutch Advice
Old Jan 13, 2014 | 11:18 AM
  #21
pettyboy69's Avatar
Originally Posted by s2klariat
Originally Posted by pettyboy69' timestamp='1389582105' post='22961864
I think it really depends how much power your looking to make and also how much and what kind of racing your going to be doing? I've ruined both competition stage 4 clutch kit and a act hdg6 kit which costs almost $900, and I wouldn't run either of them again over 450whp if your planning on doing any track racing on sticky tires I would suggest doing a twin disc. If your not planning on doing any serious launching at high power you should be fine
What power level are you at?
At that time my car had dyno'd 525whp when I had the problems with both the act and the competition disc coming apart, the pressure plate in both cases held, but the material on the discs ripped off and ruined both setups the first time I launched them at the track on sticky tires
Old Jan 13, 2014 | 12:43 PM
  #22
KaNgArOo's Avatar
Originally Posted by s2klariat' timestamp='1389583536' post='22961887
[quote name='pettyboy69' timestamp='1389582105' post='22961864']
[/quote]
Whew... I don't plan to launch at the track with sticky tires, so the competition Stage 4 should hold up!
Old Jan 14, 2014 | 02:59 AM
  #23
JJAUTOWERKS's Avatar
Former Sponsor
Originally Posted by KaNgArOo
JJauto. How much for a competion stage 4 clutch shipped to 54401? Pm me!
Pm sent sir
Old Jan 14, 2014 | 03:00 AM
  #24
Former Sponsor
Originally Posted by pettyboy69' timestamp='1389644296' post='22963108
[quote name='s2klariat' timestamp='1389583536' post='22961887']
[/quote]
[/quote]
Yes sir it will, one of our local supercharged guys here is running it with no problem. Just a thought for you, if you daily your S, traffic with the 6 puck is kind of harsh.
Old Jan 14, 2014 | 05:13 AM
  #25
Moddiction's Avatar
Former Sponsor
I'm a big fan of the ACT pressure plate and oem disc. 60K miles on that setup now and holds great. Granted I make less torque and power than you most likely will but that combo is rated for about 350 ft lbs tq.
Old Jan 14, 2014 | 12:05 PM
  #26
s2klariat's Avatar
Well I filled out a return goods application with ACT. I don't know if it'll do any good but the rep I talked to today recommended I fill it out after seeing my pictures. Guess we'll see!
Old Jan 15, 2014 | 03:12 AM
  #27
Former Sponsor
Told ya! Good luck, let me know what happens. Its worth a shot.
Old Jan 15, 2014 | 03:47 AM
  #28
wadzii's Avatar
Banned
Stock disk w/act hd plate is only good for around 400hp or so.
I'd stick w/the act plate.. all the cheap clutches use modified oem pressure plates which tend to make them drive funny. The crack in the fingers probably wont have much effect on anything. All the fingers are is a lever to move the friction ring. They dont actually do anything as far as the clutch holding power.
HD pressure plate w/the act performance street disk should hold up at 450hp for a while. A 6 puck disk is really the only thing that will hold up for a long time. Organic disks can only take so much heat.
Old Jan 15, 2014 | 04:42 AM
  #29
Moddiction's Avatar
Former Sponsor
That combo is rated for 350 torque. So more like 500 hp. A lot of people run that setup for a long time with high power numbers. I'm at 400+ hp and that setup hasn't slipped once in 60k + miles now.
Old Jan 15, 2014 | 04:46 AM
  #30
wadzii's Avatar
Banned
Depends on how you drive.. An organic disk wouldn't last me 10k miles. When I drive my car it catches hell.
