Clutch Advice
Stock disk w/act hd plate is only good for around 400hp or so.
I'd stick w/the act plate.. all the cheap clutches use modified oem pressure plates which tend to make them drive funny. The crack in the fingers probably wont have much effect on anything. All the fingers are is a lever to move the friction ring. They dont actually do anything as far as the clutch holding power.
HD pressure plate w/the act performance street disk should hold up at 450hp for a while. A 6 puck disk is really the only thing that will hold up for a long time. Organic disks can only take so much heat.
seoul2k
Sep 13, 2011 06:41 AM
so take that for what its worth.
