Clutch is dead
I was just wondering if you guys could tell me exactly which clutch you think would be good for my set up. You can see it in my sig below with power and everything. I was using the Exedy clutch but it's maybe 5,000 miles later and it's already done with. My S is my daily driver so I want something that is going to last a little bit longer. Thanks for the help.
Originally Posted by Silver S2k4,May 14 2005, 08:42 AM
Try the ACT PP and their organic clutch. I am making almost the same power as you and mine is holding up fine so far.
Anyone else?
Originally Posted by nsxinsac,May 14 2005, 10:16 AM
Which Exedy clutch were you using? Also, if it is your daily driver, how stiff do you want the pedal and engagement to be? You can get a clutch setup that will last a long time however it might not be as streetable as you would like. I put a Exedy clutch and flywheel setup on my NSX 6 month ago and the engagement was so harsh, I could barely get out of my drive way or in traffic for that matter. So I have it removed right away so I took a big hit, $2,200. Just thought I'd give you my costly experience when choosing to strong of a clutch. I have the ACT and CT flywheel right now and its fine but I have not quite broken in my setup yet. Also, are you launching your S or dropping the clutch a lot?
Originally Posted by Black Nugget,May 14 2005, 10:16 AM
I would recommend contacting Hardtopguy in regards to one of these. Its what I have and I love it!
