Clutch is dead
Old May 14, 2005 | 08:21 AM
bobmoheb's Avatar
Default Clutch is dead
I was just wondering if you guys could tell me exactly which clutch you think would be good for my set up. You can see it in my sig below with power and everything. I was using the Exedy clutch but it's maybe 5,000 miles later and it's already done with. My S is my daily driver so I want something that is going to last a little bit longer. Thanks for the help.
Old May 14, 2005 | 08:42 AM
Silver S2k4's Avatar
Try the ACT PP and their organic clutch. I am making almost the same power as you and mine is holding up fine so far.
Old May 14, 2005 | 08:48 AM
bobmoheb's Avatar
How many miles have you had it on for? Also, where is the best price you found for it?
Anyone else?
Old May 14, 2005 | 10:13 AM
only 2.5k so far. Best price is $900 on hardtopguy.com
Old May 14, 2005 | 10:16 AM
Black Nugget's Avatar
I would recommend contacting Hardtopguy in regards to one of these. Its what I have and I love it!
nsxinsac's Avatar
[QUOTE=bobmoheb,May 14 2005, 08:21 AM] I was using the Exedy clutch but it's maybe 5,000 miles later and it's already done with.
Old May 14, 2005 | 10:53 AM
evf2000's Avatar
I would also have to go with the ACT PP...I've gone about 20,000 S/C miles on mine so far and it's doing great!!
Old May 14, 2005 | 11:02 AM
bobmoheb's Avatar
Originally Posted by nsxinsac,May 14 2005, 10:16 AM
Which Exedy clutch were you using? Also, if it is your daily driver, how stiff do you want the pedal and engagement to be? You can get a clutch setup that will last a long time however it might not be as streetable as you would like. I put a Exedy clutch and flywheel setup on my NSX 6 month ago and the engagement was so harsh, I could barely get out of my drive way or in traffic for that matter. So I have it removed right away so I took a big hit, $2,200. Just thought I'd give you my costly experience when choosing to strong of a clutch. I have the ACT and CT flywheel right now and its fine but I have not quite broken in my setup yet. Also, are you launching your S or dropping the clutch a lot?
There is only one setup that Exedy makes. No I don't launch my car at all. To scared to do it right now. Need to get some extra goodies before I do that.
Old May 14, 2005 | 11:05 AM
bobmoheb's Avatar
So what would make me want to go with the above recommendation vs. going with the all out ACT set up? Also a bunch of you have recommened the ACT setup but they have more than one. Which one is it?
Old May 14, 2005 | 11:28 AM
JDMKID35's Avatar
Banned
go with a competion clutch I can get them if you need one.... do some research on them... i know a lot of ppl that use them
