codybjag turbo build
Old Dec 17, 2010 | 06:02 PM
  #41
601WHPS2K's Avatar
lets just say i have alot of work into my s2000 and DSD is right is you go cheap trust me its gonna get you a broking tranny or diff quick trying to turbo it and not think to reinforce before hand i mean i have everything you can think in the tranny now and rear end and drive train except the straight gears in the tranny and still went thru 2 tranny's in my life of the car with 611whp and now im shooting for 750whp with the new cry-o treated geared tranny i have in but heres a list of parts in my s2k given i have some i aint list:
http://sphotos.ak.fbcdn.net/hphotos-ak-snc...1_5252494_n.jpg
Engine:
stock head
ARP Head Studs
Erl Bottom End with Darton Sleeves stock bore, CP Pistons calico coated top, skirts, CP Rings, and Crower Rods – 9.0:1 Final Compression Ratio
ACL calico coated race bearings
new oem oil pump
Rick's underdrive pulleys
innovativemounts Urethane Stiffness 95A Extreme
CARBONETIC triple disc clutch
AEM EMS with Uego
HKS Twin Power Ignition Amplifier
Lovefab mini-me Manifold
garret gt 35r .82 ex Turbo
Lovefab 3” Downpipe
Inline Pro 3” Exhaust
Tial 44mm Wastegate
hks Blow-Off Valve
rc 1200cc Injectors
AEM egt probe
AEM 5 Bar Map Sensor
AEM Fuel Pressure Regulator
Walboro 255 Fuel Pump
Hondata Intake Manifold Gasket
Koyo Radiator
Blox Radiator Stays
Samco Radiator Hoses
neukin catch can
Tein hood shocks
Carbing Cooling Plate
Password JDM Fender Washers
HKS High Flow 100mm Filter for Turbo
Precision 750hp intercooler
odyssey battery PC680MJT put in trunk
PassWord JDM Mini-Battery Holder
Suspension:
Cusco subframe bracing
Megan coilovers
Inline Pro Differential Conversion Kit with Driveshaftshop Custom Driveshaft and Stage5 Axles
Nissan 300ZX Non-Turbo Differential
mickey thompson et street on stock rims (for the track)
Exterior:
Oem Front Lip
stock wheels
vis oem cf hood
vis cf trunk
oem black hardtop it has only the hardtop= no soft top at all
Volk GT-7 wheels 18/8 front and 18/9 rear
Faulken 452 tires 235/35/18 in the front
Faulken Azenis RT-615 245/40/18 in the rear
H.I.D Low Beam lights 12000k (Purple)
Interior:
Cusco 4 Point Roll Cage
S2000 Leather Shift knob
Aem oil pressure gauge
Aem true boost Gauge
AEM serial gauge
SOS 52mm dual gauge pod
AP2 Center Console
Old Dec 17, 2010 | 06:03 PM
  #42
dsddcd's Avatar
Originally Posted by codybjag,Dec 17 2010, 09:22 PM
dsddcd:
I don't need 10k to build a GOOD turbo kit. i just want a good kit and i can save for all of the other parts!! 5k will get me a kit EASY. just looking thru S2ki there isn't a single WHOLE kit selling for even 7K so 10k is crazyness. there is a shop here that does really good exhaust work ie. welding for cheap.
gamble:
damn i guess all i need is an intercooler now and ill be boosted to 550 damn thanks for the advice
You defiantly need to do more research here is the list I usually post, now you can take out the cost of the AEM but you will need a WB and boost solenoid. The Invidia will flow okay but will choke the power as you start to make more power. There are a LOT of hidden costs.
Base Turbo Kit Capible of 600WHP.............$5,000
Clutch (Parts Only)...................................$600
AEM w/ Wideband, Boost Solenoid.............$1,200
Exhaust........................................... ........$600
Injectors......................................... .........$400
Fullblown Dual Hanger...............................$1000
Rail & Regulator........................................$ 400
Heat Management / Accessories / Misc..........$500
Tune.............................................. ..........$600
Total............................................. ...........$10,300
As for the turbo kit if you want 600WHP you will need a ELT or other tubular manifold, the IP Street kit will not get past 550WHP. Even if you did purchase the base kit you would get the 5965, which would not get you past 500WHP. You will need to step up to a 6265 or comparable.
Second you will also need to purchase or build an oil filter relocation kit with is at least another $250 to $350.
Third, there is also no gaskets included, heat management, T-bolt clamps, spark plugs, oil cooler bypass hose, HD PCV valve and several other little parts.
Then you will need to get exhaust flanges, flex section, piping and have it all fabricated to meet up to the cat back.
Last but not least is to find a good tuner.
I can tell you that the parts you do get are done very well and defiantly do work.
If you are looking for a cheap VERY clean kit you may want to take a look at TrboKev's IP kit. Make him an offer minus the EMS and I bet he will cut you a hell of a deal. This is really the only used kit on the boards I would suggest right now.
https://www.s2ki.com/forums/index.php?showtopic=831361
Other things to keep in mind are some of the other parts on the car that are close the limits that will eventually break or have problems. One example are the valves, the exhaust warp very easily (though E85 will help prevent warpage) and of course there are the weak retainers on the AP1. If you plan to launch the car the differential will be running on borrowed time.
All I can say is trust me on this one you have to be VERY careful when you go FI as there is a lot of deceit out there, some intentional and some not.
Old Dec 17, 2010 | 07:09 PM
  #43
D1sclaimer's Avatar
Heres my breakdown of costs.
InlinePRO stage 2 kit: 5000
Bullshit should-have-been-with-the-kit billet wheel upgrade: 300
puddydad EGR blockoff which should have been with the kit: 15
t-bolt clmaps which should have been with the kit: 100
hiring a friend to cut and tig new aluminum to make the intercooler fit: 100
InlinePRO exhaust bought used: 500
InlinePRO oil relocation kit: 230 (I can't fully remember what I paid Scott, but think thats right)
3" stainless steel piping, flange, and new gaskets from Columbia mandrel bends: 100
Paying my friend to tig weld everything for me: 250
DEI heat shielding: 60
Full Blown dual walbro hanger: 399
2 Walbro pumps: 89 each = 178
ID2000 injectors with plug and play clips: 1019
FPR: 250
Various fuel lines and fittings: 300
AEM EMS: 875
MAC boost solenoid: 35
Hondata 4 bar MAP sensor: 125
Tune: 500
Total: 10,336 dollars.
It took that much to hit 579whp with some ignition issues which is lower than your goal of 600whp. I just spent 760 dollars on an ignition box and 248 dollars on CDI coils for the box to get more horsepower which brings my grand total to 11,344 dollars. This is still with a completely stock AP1 engine.
Good luck hitting 600whp with your 5000 dollar budget.
EDIT: I forgot to add on top of that, that I paid 50 dollars for a set of low mileage RSX coil packs.
Old Dec 18, 2010 | 12:19 AM
  #44
codybjag's Avatar
Engine:
stock head
ARP Head Studs
new oem oil pump
AEM EMS with Uego
Lovefab 3” Downpipe
Tial 44mm Wastegate
hks Blow-Off Valve
rc 1200cc Injectors
AEM egt probe
Koyo Radiator
Blox Radiator Stays
neukin catch can
Tein hood shocks
Suspension:
Megan coilovers
Exterior:
Oem Front Lip
stock wheels
vis oem cf hood
vis cf trunk
Interior:
AEM serial gauge
AP2 Center Console
i want my car just like this this is my dream but idk about 600 or 750WHP ill settle something lower and build my self up. but i have a spare diff now i just need to build it been looking around for gears but no luck yet tranny i know nothing about but if i break 400whp ill upgrade my draftshaft and i'm sure ill upgrade my diff as soon as i get gears. but ur set up is what i'm going for but just not that much power YET! ill work my way up slowly.
Old Dec 18, 2010 | 12:35 AM
  #45
codybjag's Avatar
ok i know i still have alot to buy but if i can pick up a used kit like the one scott suggested i think ill be good. i'm not looking to go 600WHP RIGHT NOW yes its a future goal. i already have the aem ems so thats a plus. i'm not going to put the turbo kit on unless i have everything ready like a clutch and whatever else i need for this inlinepro kit that Scott's friend is selling.
i'm currently building a diff.
what build would you suggest for the diff?
lets say if i bought this kit from Scott's friend? what would i need?
besides the clutch lol
Old Dec 18, 2010 | 05:00 AM
  #46
601WHPS2K's Avatar
idk what kit scotts friend is selling but im a fan of the r200 diff. swap which i have and from what i seen i have had the longest rpm range outta the friends i know with reg. diffs. and those with gears, i mean im not in vtec at 75 mph like i know a few people but again its a little costly and its how you wanna build it cuz i want as long as a gear i can get but thats hard to find for an s2k lol
Old Dec 18, 2010 | 05:03 AM
  #47
601WHPS2K's Avatar
oh and stay push dont go pull on the clutch like i did i got a carbonetics triple plate ands switched to a pull cuz the 3200 kg preassure plate inless you wanna do some crazy numbers like 700 and above
Old Dec 18, 2010 | 07:50 AM
  #48
codybjag's Avatar
ok thanks for the advice i want a R200 diff but that the kit is a pretty penny maybe later on. i guess i have to wait and see i still have awhile before i go boost. but here is the link https://www.s2ki.com/forums/index.php?showtopic=831361
Old Dec 18, 2010 | 01:44 PM
  #49
601WHPS2K's Avatar
that is a good deal for a starting package if i was getting started i would take that offer up in an instant just would have to change min. things
Old Dec 18, 2010 | 02:10 PM
  #50
codybjag's Avatar
thats my plan i want to buy a WHOLE kit i just hope it dosn't sell buy the time i have the cash.
