Cold Side Wastegate
Old Aug 6, 2007 | 12:28 PM
blackey's Avatar
Default Cold Side Wastegate
I've been wondering why a coldside (think intercooler piping) wastegate couldn't be used as a secondary failsafe for a system with boost creep issues. It would have to limit to something above the spring value in the standard wastegate otherwise the standard wastegate would never see full boost and wouldn't completely open.
AKA something like 8psi on the standard spring and 10psi on the coldside.
Old Aug 6, 2007 | 01:02 PM
slimjim8201's Avatar
While not the most efficient method (or the most elegant for that matter), a cold side wastegate (check valve) would function to limit manifold pressure. This method does not solve the fact that boost creep is occuring, and a lot of energy will be wasted as you expel charged gas through the cold-side wastegate. The proper method to solve boost creep is to avoid it in the first place via an adequately designed manifold and properly sized wastegate. Or use a smaller turbo, more restrictive turbine or turbine housing.
dsddcd
Jun 1, 2019 07:53 PM
2004TurboS
Mar 9, 2016 04:45 AM
eastonh477
May 15, 2012 01:01 PM
rikhemi
Feb 23, 2012 09:42 PM
1SlowSi
Feb 17, 2012 05:09 PM
