Compresison diff. in F20 to F22?
Old Feb 23, 2009 | 01:23 PM
J'sBlackAP1's Avatar
Default Compresison diff. in F20 to F22?
Hey guys, I recently purchased an F22C and my techinician noticed that the pistons seemed to have less of a dome than the F20C pistons in my original motor.
Lead me to beleive the compression in the F22C was lower? Is this true?
I thought the only difference between motors was stroke, cams and rev limit?
My setup will be an F20C head, 2MM headgasket and F22C block.
If the compression will be lower that will be fine since i'm running about 15-18psi.
Just wanted to hear from others doing this same setup if they know about the compression changes, if any.
ThankS!
Old Feb 23, 2009 | 01:56 PM
Sideways's Avatar
F20c is 11.0:1
F22c is 11.1:1
Old Feb 23, 2009 | 03:40 PM
Thanks, yeah I realized after the fact I should've just looked for each individual compression ratio.
Thanks man.
Old Feb 23, 2009 | 04:19 PM
chris_barry's Avatar
More capacity 550cc vs 500cc pumping into the same size combustion chamber requires less piston dome to arrive at the same compression.
Old Feb 23, 2009 | 04:21 PM
Ahhh thank you for the detailed response.
tugsta
Nov 7, 2009 06:10 AM
4s2k0
Mar 18, 2009 08:16 AM
synapse
Jan 5, 2007 11:06 PM
ArinX
Oct 26, 2004 12:33 PM
Team Hybrid
Nov 4, 2002 02:15 AM
