F22 Piston in F20
Old Nov 5, 2009 | 06:39 AM
tugsta's Avatar
Default F22 Piston in F20
Hey guys/girls,
My engine is toast. Pistons are gone, bearings, piston rings, cylinders are slightly damage.
Where i live, its quite hard to find parts, i own an MY03 s2k.
Is it possible to swap over the F22 pistons onto the F20 con rods and use them?
i know the diameters of both pistons are the same (87mm) but the head length is different.
Any inputs into this? isit possible?
what would your advices be in this type of situation?
Need some feedback.
Thanks all.
Old Nov 5, 2009 | 09:38 AM
wadzii's Avatar
Banned
what is head length?
you could do that no problem but you would see a significant drop in compression if you did.
Old Nov 7, 2009 | 05:56 AM
hondaphreak's Avatar
put in a thinner head gasket would adjust the compression back towards the higher end though... or would it?
Old Nov 7, 2009 | 06:03 AM
wadzii's Avatar
Banned
it would raise the compression a little, but why use those pistons in the first place if you are just going to use a thin hg to raise the compression back up?
f22 pistons in an f20 might be something to do if you want lower compression for a turbo motor w/o sleeving the block or whatever. for for a stock rebuild or NA setup its worthless.
Old Nov 7, 2009 | 06:10 AM
its pretty hard to find after market pistons made for the frm walls though and theyre pretty expensive too. so i guess the f20 pistons would still be best. but what about the h22 pistons they have the same bore dont they? are they any taller or shorter?
Fabulous_omelet
Sep 13, 2015 02:27 PM
Fabulous_omelet
Sep 4, 2015 12:02 PM
ABCVTEC
17
Dec 13, 2012 08:29 PM
bois2k
Jul 12, 2010 09:16 AM
BMACMAC
Jan 22, 2007 07:55 PM
