Comptech FMU / EMS
Old May 19, 2006 | 07:40 AM
MB's Avatar
MB
Member
Default Comptech FMU / EMS
Tried search etc.
Im not sure what fuelling bits the Comptech S/C comes with, but presume its a FPR (FMU) that sits in the return line as per the Vortech, and an ECU piggyback box?
Does anyone have pics of them both fitted?
Clearly aftermarket managment is wise, but is anyone using their's with no issue?
Cheers,
MB
Old May 19, 2006 | 08:46 AM
markS2kcU's Avatar
No ECU piggyback in the kit, just a ESM that clamps the map voltage, 4 wires to cut or splice.
Red thing behind the header tank is the FPR.
Issue's, yeah.
Old May 19, 2006 | 08:47 AM
MB's Avatar
MB
Member
Mark where the hell have you been?!
PS - just realised you posted on my install thread too
MB
Old May 19, 2006 | 09:00 AM
markS2kcU's Avatar
Best say I've been a bit busy with other sh!t, just house and family stuff.
Old May 19, 2006 | 09:01 AM
MB's Avatar
MB
Member
Nuff said
YHPM
MB
Old May 19, 2006 | 11:20 AM
r_duff's Avatar
LHD setup. the FMU is at the top right corner of the engine bay
Old May 19, 2006 | 11:32 AM
SC-S2000's Avatar
no picks of the bay or the ESM but i havent had any problems running the comptech kit the way it comes.
Old May 20, 2006 | 03:16 AM
MB's Avatar
MB
Member
Thanks both.
I never could find the bloody fuel lines! Pic of where they are would be great.
MB
Old May 20, 2006 | 05:44 AM
AusS2000's Avatar
The fuel line comes up through the intake and goes into the rail under the damper (white mushroom thing). The return is further back and is the lower connection on the OEM FPR.
When you install the Comptech FPR you remove the stock one and replace with a fitting. The lead from the fitting is a braided hose that goes to the Comptech FPR and there is a rubber hose from the FPR back to the return line. You also extend the vacuum line to the FPR location.
Old May 24, 2006 | 12:15 AM
grantedS2k's Avatar
DBM, I think you're on the same path as me! I'm convinced with the Comptech setup, and I'm now hunting one down!!
