Comptech Installation
Old Nov 25, 2005 | 02:09 AM
Trip's Avatar
Default Comptech Installation
Hi All,
Is it possible to Install a Comptech S/C gradually , having the car drivable during this process.
The only thing which comes to my mind is the Pulley.
What about the fuel pump ?
Thanks
Old Nov 25, 2005 | 04:31 AM
xviper's Avatar
Yes, no boost, no need for the stuff that's associated with boost, so as long as the belt stays off, you can put almost everything else on in stages and continue to drive the car. Just make it has filtered air.
Old Nov 25, 2005 | 04:34 AM
Trip's Avatar
thanks XV.
the extra fuel pressure with the uprated fuel pump won't be a problem then .
Old Nov 25, 2005 | 08:42 AM
xviper's Avatar
Originally Posted by Trip,Nov 25 2005, 07:34 AM
thanks XV.
That's correct. The new fuel pump will pump at the higher rate and pressure, but the regulator only responds to boost.
Old Nov 25, 2005 | 09:08 AM
MB's Avatar
MB
Member
Trip,
I did the fuel pump early on, it will still only use what it needs.
Have a look at mine and also Xvipers post, we did things in different orders so you can pick and choose.
https://www.s2ki.com/forums/index.ph...&f=25&t=325803
Im currently driving with the blower and aftercooler on, but no belt and no oil supply. Not ideal and you cant go fast at all, but I need to use the car inbetween installing.
MB
Old Nov 25, 2005 | 11:10 AM
Trip's Avatar
Thanks guys.
I read all your Post MB. the fuel pump swap will help
Old Nov 28, 2005 | 02:48 AM
spider2k's Avatar
Active Streak: 30 Days
why wouldnt you just get it done in one go and be finished?
Old Nov 28, 2005 | 06:15 AM
xviper's Avatar
He's probably like I was. I just didn't have the time to dedicate to this all at once and I didn't want to tie my car (daily driver) up that long. Not all of us are impatient. Besides, for one single person doing this work, it can take a whole weekend of 10 to 12 hours days. Sorry, I've got other things to do on my weekends. Also, it has been reported more than on one ocassion, that rushing this has resulted in mistakes - mistakes that took much more time to backtrack and fix.
Old Nov 28, 2005 | 06:37 AM
Trip's Avatar
well said.
flyboy56
Jan 24, 2008 03:16 PM
elusiv
Aug 6, 2006 11:31 AM
Silver S2k4
May 11, 2005 05:50 PM
S2000_Europe
Apr 15, 2004 03:18 PM
