Wrong Fuel Pump for Comptech?
Old Aug 4, 2006 | 06:57 PM
elusiv's Avatar
Default Wrong Fuel Pump for Comptech?
Hello,
I just realized I picked up the wrong fuel pump for my Comptech kit. I picked up the GSS317 and i know i need the 342.
With that said, I just did a quick search and and i think i saw someone using the 317 on their CTSC. Can I actually use this? or is the 342 the only thing that works?
thanks in advance
Old Aug 6, 2006 | 01:22 AM
markS2kcU's Avatar
The GSS317 isn't a high pressure pump, the GSS342 is.
The Walbro high output in-tank electric fuel pumps are available in flow ratings of 255 liters of fuel per hour. These particular pumps flow significantly more fuel at higher pressure. For example, at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour.
Old Aug 6, 2006 | 04:52 AM
MB's Avatar
MB
Member
Update on your progess Mark??
MB
Old Aug 6, 2006 | 07:54 AM
elusiv's Avatar
thanks guys. i have the gss342 on order and im going to return the 317. thanks for all the help!
Old Aug 6, 2006 | 08:19 AM
MB's Avatar
MB
Member
Are the Vortech & Comptech supplied pumps the same?
MB
Old Aug 6, 2006 | 09:32 AM
markS2kcU's Avatar
Probably.
Old Aug 6, 2006 | 10:04 AM
icemans2k02's Avatar
whether they are the same brand i dunno but i know they are with same specs as the walboro 255
Old Aug 6, 2006 | 11:21 AM
MB's Avatar
MB
Member
Cool ta.
MB
Old Aug 6, 2006 | 11:31 AM
cpoz's Avatar
FYI: The Comptech pump is a walboro 255
slicko9
May 17, 2010 09:13 AM
Hot.Damn
Aug 15, 2007 01:41 PM
yellowknockers
Feb 9, 2005 07:21 AM
S2000_Europe
Apr 15, 2004 03:18 PM
AusS2000
Oct 19, 2003 09:58 PM
