Comptech pulley removal
Guys, what the best way to remove the pulley on the blower?
Also are the threads on the bolt the normal way, like lefty loosey, righty tighty?
Thanks.
Done now.
Thanks.
Done now.
Thanks.
Done now.
Thanks.
Done now.
Using some large grips and some rag you can hold the pulley still enough to loosen the bolt without damaging the pulley. Then loosen the top three bolts off on the SC and you can pull the SC forward enough to slide the pulley back.
We took the pin out first to allow us to slide the pulley off more freely.
Its not an easy job but we changed the pulley and re-tensioned the SC in 20 minutes.
Herbo.
Originally Posted by mark_m,Aug 17 2005, 11:46 PM
Just a quick update on this, when coming to tighten the pulley bolt DO NOT put a wrench on the bolt holding the blower blades, it will shear off.
Whoops.
Whoops.
I used the same method, large grips and cloth to hold the pulley, the bolt has to be tight bu not that tight, the key takes the load so there is little oposing force on the bolt. It just needs to be tight enough to prevent vibration loosening it.
Have you managed to get what's left of the bolt out ?
Herbo.
