Comptech SC Upgrade
Originally Posted by Grimnebulin,Jul 2 2010, 11:43 AM
Just getting my car back this weekend. Here are it's Dyno numbers...373rwhp/242lbft tq @ 10psi.
It's an '07 S2K with the new CT Engineering SC (Novi 1220SL), Comptech header, 550cc injectors, T1R 70mm Stainless Exhaust (Catalytic Converter still installed as I'm in in CA), 91 octane gas, and tuned with Hondata FlashPro.
Originally Posted by jemje2006,Jul 2 2010, 05:08 PM
does your setup pass CA's smoke???
Everything on it really is smog legal and both the header and SC are smog legal and stamped with the correct certificate numbers. Except the current pulley.
So if I ever have to go to a ref station, all I have to do is swap out the smaller pulley for the larger stock 5psi one and I should be totally fine. I setup the car to be fully smog legal/really easy to quickly get back to smog legal.
Originally Posted by Grimnebulin,Jul 2 2010, 04:24 PM
Yes - it passes visual inspection.
Everything on it really is smog legal and all the header and SC are both smog legal and stamped with the correct certificate numbers. Except the current pulley.
So if I ever have to go to a ref station, all I have to do it swap out the smaller pulley for the larger stock 5psi one and I should be totally fine. I setup the car to be fully smog legal/really easy to quickly get back to smog legal.
sorry, i mean the sniffer test at a smoke center(not to ref) since you are running 10psi
Originally Posted by jemje2006,Jul 2 2010, 05:28 PM
for sure, you can pass visual by the CARB#.
