Comptech w/ Aftercooler suggestions
As right as it can be. There would be no point in installing MAP > VAFC > ESM > ECU as the ESM would still limit the value. By installing MAP > ESM > VAFC > ECU you can adjust the MAP value before and after it plateaus.
Just remember that the ESM caps it for a reason. The ECU doesn't like values higher than 2.9V. You need to play with fuel pressure and injectors sizes to properly tune.
It's not useless. Used in cahoots with a rising rate regulator and other injectors it's sort of ok. What I don't understand though is why you would buy a 30K car, a 5K supercharger and tune it with a $300 ricers foible.
Originally Posted by cmrs2k,Apr 5 2005, 01:54 PM
I was looking at the AEM EMS, is that a good alternative to the VAFC? I have ZERO experience with both...
-c
-c
Its useless
