Is this the correct flow path?
Old Aug 6, 2010 | 07:56 PM
AFs2k's Avatar
Default Is this the correct flow path?
There's not a lot of info on this setup, so I'm having to ask.
I need to know if this is the correct way this is supposed to be installed. I have never had to run an oil cooler before and I don't know anything about the way the oil flows from the block into the filter and whatnot... Is the center hole the return and the outer hole the pumped oil. I know I should know this seeing as I have torn down and rebuilt lots of stuff... anyways, is this right:
The setup:
The way the flow is supposed to be through the plate:
d1000rr
Jun 2, 2019 06:13 PM
MorngWoodStewie
Mar 26, 2017 06:10 PM
goldenfri
Jun 7, 2016 06:37 PM
kevos2k
Sep 17, 2012 06:13 PM
bruce0293
Jun 11, 2009 12:21 PM
