Cracked Greddy Log Manifold & Removed :)
Old Oct 10, 2008 | 07:03 PM
  #111
Chris_Lum's Avatar
Originally Posted by JoeyBalls,Oct 10 2008, 06:46 PM
Just curious the Wastegate flap and actuator don't really move at all, is that normal?, I mean I have'nt/dont plan to manual actuate it, but was wondering if its normal that it is pretty solidly in place......
if hte wastegate flapper is still connected to the actuator arm, then you will have a hard time moving it with your fingers alone! you need vacuum to the top of the actuator to get it moving.
Now if you have disconnected the actuator arm from the flapper and the flapper isn't able to move smoothly, then you would have problems.
Old Oct 10, 2008 | 08:30 PM
  #112
Spec_Ops2087's Avatar
Originally Posted by JoeyBalls,Oct 10 2008, 08:18 PM
no, no fine scratches, the turbines look very clean, however there was a small amount of oil on the charge pipe that guides the air intp the turbo, it was very small amount..... what gasket are you referring to?
My turbo looks like its in decent shape right?
Thats normal, my turbo has a little oil in the same place.
brownieap1
Jun 8, 2014 07:05 PM
AFs2k
Dec 1, 2010 12:57 PM
cloudx71
May 21, 2009 02:17 PM
Ahnold
Apr 16, 2009 03:25 PM
