Cracked v160 case
Old Sep 26, 2012 | 07:45 AM
  #21
camuman's Avatar
guess it aint bullet proof
Old Sep 26, 2012 | 07:50 AM
  #22
bobbyrandolph440's Avatar
Get a scatter shield
Sent from my DROID RAZR using Tapatalk 2
Old Sep 26, 2012 | 10:36 AM
  #23
SgtDuracell's Avatar
so thats why you asked me for a towhook that day....
damn that sucks. sorry to hear.
Old Sep 26, 2012 | 06:43 PM
  #24
p0staboy's Avatar
looks like the bad U joint that broke off caused the case to crack. THANKS A LOT DSS FOR YOUR POS SHAFT
Old Sep 26, 2012 | 06:59 PM
  #25
liquidgsr's Avatar
So much for upgrading the diff and trans and being golden.
Old Sep 26, 2012 | 07:01 PM
  #26
Slows2k's Avatar
Originally Posted by hybridsol
Originally Posted by Slows2k' timestamp='1348623061' post='22038209
There are a list of tolerances that can stack and cause both failures.
Explain more?
Looks like the universal joint just popped apart... expected to see something (joint) ripped open.
Are you thinking the case cracked when the universal joint was 'jammed up'? Did the diff pull away/move towards the rear?
That's *very* scary- car could have easily flipped over...at 125mph.
Every part to adapt the getrag trans to this car has the possibility of misalignment. The trans adapter, rear mount and propshaft.
Old Sep 27, 2012 | 08:22 AM
  #27
s2000gt35's Avatar
i dont knowm if its me but i think your drive shaft is installed on the wrong side. Mine has the slotted shaft on the tranny side not on the diff side or maybe mine is not on the right side. loll
Old Sep 27, 2012 | 08:43 AM
  #28
spectacle's Avatar
Nothing is. The more honest people are on this forum, the more people will see the truth.
Old Sep 27, 2012 | 09:38 AM
  #29
hatchbone's Avatar
No transmission is "bulletproof ", some just stronger then others in this case its not the trans or the adapters that failed its the u-joint that failed.a chain is only as strong as the weakest link that link being the u-joint in this case, there are many v160 conversions getting beat a lot harder then this with no issues, mine worked great till I missed 3rd at 9000rpm was not the trans fault I toasted the syncro it was mine for noob shifting it early nothing you can do about it in that situation
Old Sep 27, 2012 | 10:09 AM
  #30
So what set up are u going to now
