Crank Play :(
Pretty damn close to being torn down. With the girdle there it would be a nightmare to do it looking up at it. With trans and all the other stuff already off, we contemplated just pulling the motor and checking it but Dana decided that if this one doesn't last he would just put a built one in.
Not much to share. Push the crank back, insert a feeler gauge behind the washer and was able to roll the crank and get the washers to drop out. Really long feeler gauge required.
It's easier with the girdle out, which could be done in car as well. the drive belt and transmission mainshaft will keep the crank in the car, no need to remove connecting rods. Reuse the main bearings.
Possible to replace main bearings with a crank in the car as well.
