...custom GT30 build...
Old Jun 1, 2009 | 11:05 AM
  #101
MADjdm's Avatar
Originally Posted by 300sx,Jun 1 2009, 10:57 AM
There's a heat shield in there off the battery mount, there's pics in here somewhere. Seems to be working just fine...
Hoping to hit either the track or a dyno real soon, will post results whenever there are some
Ah I do recall seeing the picture now that you mention it.
Looking forward to seeing how the dyno/track goes
Old Jun 10, 2009 | 04:55 PM
  #102
300sx's Avatar
Well I was hoping to have some track numbers today but they were closed due to rain
But on a good note that gave me a chance to setup Boost vs. VSS in the AEM with my new wastegate spring that showed up today.
I swapped out my 10.5psi wastegate spring in favor of a 4.5psi spring in hopes of making 1st and 2nd gear usefull on the street. This is the first car I've ever set up Boost vs. VSS on and I love it!
Here is a full traction 1st through 4th pull on super shitty Fuzion 245's (hey they were cheap ) with about 3.5 negative camber!
As you can see here (top left window) I had 3rd and 4th gear setup to run 12psi but since the closest breakpoint (top right window) was 10.69psi I had to guess a little and was off. It is now fixed...
Old Jun 17, 2009 | 06:46 PM
  #103
300sx's Avatar
Finally got to the track....
https://www.s2ki.com/forums/index.ph...f=142&t=708396
Old Jun 17, 2009 | 06:59 PM
  #104
Soul Coughing's Avatar
great times and traps at the track! Congrats man!
Old Jun 17, 2009 | 08:52 PM
  #105
Shftat9k's Avatar
What kind of numbers did you put down and at what PSI? Did I miss it? Awesome build, I wish I had some welding skills.
Martin
Old Jun 18, 2009 | 06:31 AM
  #106
S2Kart's Avatar
Where did you get your exhaust flange? I'm looking for another source other than SPD Exhaust.
Old Jun 18, 2009 | 01:36 PM
  #107
300sx's Avatar
Thanks guys!
Shftat9k, haven't dyno'd it yet, hopefully soon...
S2Kart, got it at http://www.t1raceparts.com/
Old Jun 18, 2009 | 02:01 PM
  #108
S2Kart's Avatar
Originally Posted by 300sx,Jun 18 2009, 01:36 PM
Thanks guys!
Cool thanks. Getting ready to start my manifold - hopefully the ArcMaster 185 is going to be as nice to use as I've heard.
Old Jun 29, 2009 | 06:26 PM
  #109
dibi's Avatar
that mani looks like the one scott at ballistic made me. Love the design and your build. Wish i knew how to weld and tune. Awsome project
Old Jun 29, 2009 | 11:08 PM
  #110
SFV_S2k's Avatar
I took the last hour to read the entire postings and I must say very impressive job, from welding to fitting everything in to make the package look perfect!
Love the custom brackets all over the car !!!
WOW !!!
