Daily driver turbo
Old Jun 5, 2013 | 07:39 PM
  #21
dsddcd's Avatar
I will give you a little piece of golden advise.
Never modify your daily, it will only lead to trouble. Get yourself another car for a daily then go crazy!
Old Jun 5, 2013 | 08:44 PM
  #22
s2kdrill's Avatar
I can't give up on my s addiction :[ I have a beater I could take out if anything happens to it while I get it fixed up if anything and as I respect your golden advice it's too much to let the S go.
Old Jun 6, 2013 | 04:48 AM
  #23
baZurk's Avatar
I am in the same situation. I just love driving the S. I will be boosting it eventually.
Old Jun 6, 2013 | 07:09 AM
  #24
watch0bak's Avatar
Originally Posted by bruthaboost' timestamp='1370455390' post='22588601
I'd argue the track forged kit is the least intrusive of the turbo kits out there. Don't need to relocate ANYTHING, however the manifold is big so will have enormous radiant heat. Be also aware though you will make more hp/psi, the spool does slow down a bit as the runners get longer (which makes sense when you think about it). Somewhere around is a post of a member who has dynos with the same car, turbo, psi, and different manifolds; one tubular, one "log." The log spools faster, but wasn't nearly as efficient. Keep in mind, if your turbo will get you to your power goal with a quicker spool in log, just get that. There's no point in chasing efficiency numbers if you aren't trying to squeeze every PSI you can get out of pump gas.
Last thing and it can't be stressed enough. Make sure you have addressed containing/shielding all that radiant heat you're going to produce. Oddly, none of the kits out there (save PTuning) address this.
thanks man, makes lots of sense, I'm going to start planning for the forged kit as soon as possible I'm guessing!
Have the same kit and haven't had any problems since I got it! Not having to relocate anything is amazing! Although I think I will eventually relocate the AC line!
Old Jun 6, 2013 | 11:53 AM
  #25
boostedf20c's Avatar
Running the Inlinepro Stage 2 kit 509@19psi Daily driven :thumb up: No issues even make long road trips often. Its all about how you treat the car.
Old Jun 6, 2013 | 11:55 AM
  #26
baZurk's Avatar
Do you have a build thread? Could you post a link?
Old Jun 6, 2013 | 12:01 PM
  #27
Do not have a build thread yet, but you can view some of the photo's I have. Should have a thread completed by the end of the week
Old Jun 7, 2013 | 09:52 AM
  #28
s2kdrill's Avatar
wow 509whp daily driver s2000... you sir have my respect! hahaha
Charstar604
May 16, 2018 10:33 AM
cesarortiz
Nov 17, 2011 06:19 AM
TurboBusa
Oct 13, 2008 04:08 AM
StatixNWH
Feb 11, 2007 06:41 AM
