damn! wrong map sensor
Old Mar 23, 2013 | 05:14 PM
08s2000CRbackinblack's Avatar
Default damn! wrong map sensor
i have an ap2. i just bought a used hondata 4-bar not knowing it was the wrong one. are the 2 map sensors the exact same thing just with different shape or are they totally different as far as how they read pressure. can i wire the ap1 style map sensor into my ap2 harness or am i totally screwed??? they are both 3 wire sensors
please help
Old Mar 23, 2013 | 06:50 PM
herecomesboost's Avatar
The 2000 (AP1)-2005 (AP2) use the same map sensor. Also, no wires to splice. It's a plug and play install.
Old Mar 24, 2013 | 03:52 AM
i have a 2008, definately different sensors. can i make it work?
Old Mar 24, 2013 | 04:53 AM
CoolGuy094's Avatar
No. Sell yours and buy a correct one.
Old Mar 24, 2013 | 05:18 AM
s2kseven's Avatar
i have science of speed map - yours for $50.
Old Mar 24, 2013 | 06:59 AM
liquidgsr's Avatar
Yes you can make it work. You just have to run the the correct wires to it and run vac to it.
Old Mar 24, 2013 | 07:01 AM
liquidgsr's Avatar
Leave the stock one in its location to cover the hole. The non Dbw won't fit there.
Old Mar 24, 2013 | 07:04 AM
Didn't realize that you have an 08 (suppose I should have looked at your username lol). The 06+ use a different map sensor. I would recommend picking up the correct part.
Old Mar 24, 2013 | 09:18 AM
of course getting to correct one would be best but if i cant sell this one i dont want to be out 100 bucks. if worst comes to worst i could make this work, seems pretty straight forward on wiring it up. just want to make sure it can be done and it will read the map as it should
Old Mar 24, 2013 | 09:22 AM
I understand. They are both 0-5v. Pretty sure the only difference is the housing/mounting bolt.
ScienceofSpeed
Jan 24, 2011 01:17 PM
robertjr314
Jun 2, 2010 06:34 PM
UsmcSway
Oct 22, 2008 05:23 PM
jason4207
Sep 2, 2005 11:10 AM
