Detination w/ Test Pipe & Greddy Kit
Old Feb 25, 2008 | 09:10 AM
JoeyBalls's Avatar
Thumbs down Detination w/ Test Pipe & Greddy Kit
Hey, because the Greddy Kit is tuned rather rich, how much damage could you do running a Test Pipe, & Cat-back with the Greddy Kit, limiting the boost to 8psi with a Boost Controller. Reason I ask is I am getting it tuned in April, but will be putting the kit on in the next week or so, so I would rather put the Test Pipe in now when I am doing all of the wor, but don't want to sacrifice the motor if ya know what I mean. What are the dangers of doing this without a Tune, is it detonation?, or Boost Spike <-----can that be cured with a Boost Controller?
Old Feb 25, 2008 | 12:02 PM
Mr.Aqua's Avatar
I would leave the test pipe out and put it in right before you tune it. That's what I'm planning on doing.
Old Feb 25, 2008 | 12:45 PM
devs2k's Avatar
it's not difficult to put the test pipe in later on.. just leave it off until you get it tuned..
IIRC, the greddy base map is tuned for a 80mm cat back with a stock cat.. what will you be running before the tune?
Old Feb 25, 2008 | 12:49 PM
S2Kart's Avatar
Your min boost will be determined by the WG spring, so even with the boost controller off you will probably be at 8psi. Although I think the tune is still rich enough to keep you out of detonation with a test pipe, that is a big risk to take. It would be easy to put in on later.
You can also drive awhile without ever going into boost if you have extreme self-discipline
Old Feb 25, 2008 | 01:41 PM
JoeyBalls's Avatar
yeah, Ill just run the 70mm Invidia for now, then the day before the tune Ill throw the Test Pipe on, safe bet
Old Feb 25, 2008 | 06:36 PM
PatS4P's Avatar
Banned
window heat, pitot heat, time to eat
Old Feb 26, 2008 | 08:57 AM
AP1NYT's Avatar
So if i am already running a 70mm test pipe and 70mm exhaust and i install the greddy kit, will i get detonation?
Old Feb 26, 2008 | 01:54 PM
JoeyBalls's Avatar
hahaha thats great, try and get an airplane where the Pitot Heat is on all the time though Airlines have made me lazy
Old Feb 26, 2008 | 03:05 PM
cloudx71's Avatar
If you get a test pipe get it retuned. Plus you will feel much better at least getting a professional to take a look at the map and make sure your a/f levels plus timing is on track.
Old Feb 26, 2008 | 03:30 PM
S2Kart's Avatar
Don't know for sure. The stock ECU will still pull timing if the knock sensor detects it, and the base tune has headroom, but I wouldn't chance it.
Dwnfrce
Sep 30, 2018 05:07 PM
Forgottens2k
Dec 12, 2015 07:38 PM
s2kbtos
Sep 8, 2009 06:19 AM
TRBOKEV
May 2, 2008 04:07 PM
JoeyBalls
Feb 14, 2008 08:48 PM
