Difference between 05 and 06+ Comptech supercharger kits?
Originally Posted by liquid_helix136
3.2" pulley and only hit 300whp??
You HAD to have been slipping and not hitting anywhere near full boost.
I checked the belt but nothing also I ran compression test no leaking so no clue.
From: The land of corruption, cachaça, and caipirinhas.
Originally Posted by lleron' timestamp='1383013100' post='22851053
I'm looking start slowly piecing together parts for a supercharger build, and would like to stick to used parts to keep costs down. As most kits for sale here are for 04-05, I'm looking to find concrete answers for what the differences between the 05 and 06+ kits are.
To change from a 04-05 S-2000 kit to a 2006+ kit you will need the following;
- Offset inlet hose
- Fuel injectors x 4 -)
- Flashpro
- Airtemp sensor retainer
- Chassis dyno tune -
There is no ECU flash from Hondata for the 2006+ S-2000 so you will need to get the car tuned on a chassis dyno.
I'm in the same boat. The above was a reply by CT-Engineering. Hope that helps. There are actually other upgrades folks in the FI section recommends such as map sensor, monitor/fail safe gauges, better water pump & heat exchanger, different spart plugs. You have to make the call yourself.
What I gather from others that went through this route some essentials as a good tuner is a must.
- Offset inlet hose
I may be doing something similar next year, so any assistance would be greatly appreciated. Thanks!
