diodes for boost solenoid?
Old Sep 19, 2013 | 01:23 PM
08s2000CRbackinblack's Avatar
Default diodes for boost solenoid?
i am about to hook up my boost solenoid and was reading the hondata help files and is says........
"Most boost control solenoids will need a suppression diode to block the voltage spike when the solenoid is de-energized. The suppression diode should be installed close to the boost control solenoid with the diode anode (stripe end) wired to the +12V supply from the ECU, and the cathode wired to the wire to ground."
i have the boost solenoid straight from hondata ( btw i am using flashpro) and was wondering if you guys who have boost solenoids are running the with or without diodes. also if your running a diode how did you wire yours up? i have no clue about diodes but hooking up a 12v source and a ground together with a diode in between doesnt sound good but then again i dont know how it works. thanks for any advice
Old Sep 19, 2013 | 03:07 PM
Spoolin's Avatar
I'm not using one and have never heard of this before. Never had a problem either.
Charper732
Jun 9, 2017 06:56 PM
liquidgsr
Feb 4, 2013 06:32 PM
jordannn93
Sep 29, 2012 09:46 AM
crav3s2k
Feb 17, 2009 05:48 PM
shauminside
Aug 8, 2004 06:45 AM
