Dip Stick pops up consistently.
Old Aug 31, 2011 | 03:27 AM
RAIN H8R's Avatar
That does work to a point, but oil vapor/fumes/whatever is left after the catch can hurts octane, and directly affects the performance of the engine/tune.
Old Aug 31, 2011 | 05:05 AM
fastkx125's Avatar
Yea there's only so much you can do in this situation, I guess just vent the block to a atmospheric catch can and change your oil more frequently.
Old Aug 31, 2011 | 11:24 AM
BrockB's Avatar
Originally Posted by RAIN H8R
stop recirculating your valve cover to the intake. Run a 1/2 hose from the valve cover to a catch can that has has two inlets. depending what valve cover you have (what year is it?), somehow remove the PCV valve in exchange for a fitting with no check valve. Run that the the other inlet of the catch can. That should solve any/all dip stick issues.
Heres a picture of my setup. AP1 with an 06+ valve cover. Notice I do not have a catch can yet, I am just dumping to the ground by the oil pan plug
Old Aug 31, 2011 | 11:30 AM
s2000Junky's Avatar
Originally Posted by RealStreet
If you're moving enough air past the rings to pressurize the crankcase and eject the dipstick it's in trouble. What do you have connected to the vent hose on the valve cover? I've seen people that were running their engines hard enough that the misfires were shaking the rings, causing a loss of ring seal.I've also seen people make the mistake of having a "boosted" hose going to the valvecover...That's a mess. You should do a compression/leakdown test first. If the engine is healthy you can just increase the vent size to keep things in check.
Thanks
Jay Meagher
That occurred to me as well but didn’t say anything. Sounds like excessive blow by. Which isn’t a favorable situation for a motor. Makes me think motors with this situation are permanently wounded.
Old Sep 1, 2011 | 04:59 AM
EOE's Avatar
EOE
Hmm cleaned gaskets and so far so good no more popping up. Time will tell gents.
Old Sep 1, 2011 | 07:45 AM
japancrx90's Avatar
wich gasket you cleaned ?
Old Sep 1, 2011 | 08:57 AM
EOE's Avatar
EOE
Dipstick ones. The 2 green ones.
Old Sep 1, 2011 | 09:00 AM
Soul Coughing's Avatar
Smart idea, change the gaskets on the Dipstick, they wear out over time. Turning the dipstick 180 degrees helps as well. If you think you have blow-by issues, do a leak down test.
Old Sep 5, 2011 | 10:33 AM
EOE's Avatar
EOE
Did it again. I got concerned and went to Ballistic Motorsports so he could do a compression check for me.
2004 AP2 S2000 with 120k miles. All Cylinders were 255-260 and I dont burn oil. So thats good news. I filliped the dipstick 180 degrees and it seems to be staying that way. Time will tell.
Will keep you all posted.
Old Sep 5, 2011 | 10:42 AM
james0933's Avatar
That's a lot of miles.
