Dip Stick pops up consistently.
Did it again. I got concerned and went to Ballistic Motorsports so he could do a compression check for me.
2004 AP2 S2000 with 120k miles. All Cylinders were 255-260 and I dont burn oil. So thats good news. I filliped the dipstick 180 degrees and it seems to be staying that way. Time will tell.
Will keep you all posted.
Really? Are you speaking from experience or hearsay, b/c I had it and never had an issue with that.
GoOn3 I don't know man? Just a healthy engine I suppose or hope.
BTW Has any one else notice that on CT-Engineering's/Comptech's website and their own images it shows a dipsticks that is 180degrees as well? They might know some we don't? lol
Mine been holding in real well and actually doesn't even pop up past the first seal never mind flying up. CHECK IT...
Be sure to not only compression test but leakdown test. It's easily done. If everything checks out fine. Eliminate your current crankcase setup. Run two -8's or -10's off the valve cover to a breather can with a good size filter.
Originally Posted by RAIN H8R' timestamp='1314789131' post='20930220
I partially agree. The PCV only works when it seems vacuum. Otherwise in boost it closes and your left with just the front vent to flow air, which isnt enough. The Vibrant oil scavenger oil cap is nice, but it blows out too much oil.
AllStock27
Jul 10, 2005 04:30 PM
