dipstick issues..
Old Sep 2, 2009 | 10:00 PM
smirfs2k05's Avatar
I put a spring on my dip stick since it used to pop out at the track all the time since I've put a spring on it no issues.
Old Sep 2, 2009 | 11:10 PM
jdnissanz's Avatar
Originally Posted by DeadZero,Sep 2 2009, 09:50 PM
then again i have 0 crank case pressure LOL
And how was this achieved???
Old Sep 2, 2009 | 11:24 PM
DeadZero's Avatar
i have a set-up that reliefs crank pressure up to 1500hp, if not much more. Look at my uhhh my link page in my signature. Custom lines going into a oil catch-can. My tuner says that 2 of the lines is capable to relieve up to 1000hp. i have 4 lines. Just check out my build info.
Old Sep 2, 2009 | 11:26 PM
DeadZero's Avatar
https://www.s2ki.com/forums/index.ph...ic=704316&st=0
Old Sep 3, 2009 | 01:09 AM
S2oooNvegas's Avatar
Originally Posted by DeadZero,Sep 2 2009, 09:32 PM
where is this? i use synthetic mobil 1 10w-30 in my car?? always have. where is this information of it being bad for our cars????????
Shit i havent replied in that thread in YEARS. when i have a spare hour to spend ill try and hunt it down. thats OLD news dude.
Old Sep 3, 2009 | 01:21 AM
Originally Posted by DeadZero,Sep 2 2009, 11:26 PM
My input on that setup....
If you like rediculous, thats the setup to have. Theres zero need for that. Its actually detrimental to a street car.
Have you ever measured your crankcase pressure? Number one concern is, IF you have any pressure building,,, great that setup you have is relieving it. BUT you have no vacuum in your crankcase, so A: you have nothing helping the rings to seat, lame. B: IF there is crankcase pressure that means you have combustion gas making it into the crankcase and again, having NO vacuum your not scavenging those fuel vapors out of there. They are mixing with your oil, shortening its life and wear capabilities.
That setup is a drag race only setup. where you change the oil after every event, and your just waiting for your experimental engine to explode. That setup saving you from track oildown and possible DQ.
BUT you have a street car, so that scenario isnt your daily life is it?
A simple setup with say krank vents would benefit you greatly. If you really want, a small can to catch any traveling oil, then you put it inline with the vac side of the setup between the pcv valve and the valve cover.
Thats my .02c
Old Sep 3, 2009 | 05:26 AM
jwa4378's Avatar
I ran Mobil1 with 0 issues while NA and turbo...
John
Old Sep 3, 2009 | 06:52 AM
S20004ME_PDX's Avatar
subscribed, to see the information on mobil1 being bad for our cars. I've been using 5w30 synth since 2002.
Old Sep 3, 2009 | 08:37 AM
MugenRioS2k's Avatar
M1 synthetic 10W-30 (4Q) + 1Q of Lucas Oil Stabilizer
Both NA and FI
Old Sep 3, 2009 | 08:57 AM
DeadZero's Avatar
Thats my .02c
everything that is running on my car is running perfectly. Vacuum is perfect and sucking air in all area's and relieving pressure in all area's. There's nothing lame about it either. but im not gonna discuss my build with you besides just saying that i have 0 crankcase pressure
...BUT the other topic... i've been using mobil 1 on my S for almost 5 years now with 0 issues. hahaha what in the oil causes a problem for our motors? What makes it different from other company oil? those are the questions im interested in.
