Direct Port Methanol Injection Setup
Old Apr 26, 2011 | 09:50 PM
  #161
s2000Junky's Avatar
The mcmastercarr water solenoid works great. No need for check valves if your running it close to the injectors, it is the check valve.
Old Apr 27, 2011 | 06:29 AM
  #162
sujo's Avatar
If this was already covered I apologize - Are you running 50/50 mix? 100% meth? or what are you planning to run?
Old Apr 27, 2011 | 01:57 PM
  #163
EternalLx's Avatar
I mix my own 70 meth 30 water
i would do 75/25 but the flow sensor needs a minimum of 30% water to operate
Old Apr 28, 2011 | 05:21 AM
  #164
Redline S2K's Avatar
I was on devils own's website and they have an option to upgrade to a direct injection setup, but I'm not sure which base kit to get. I guessing the 2 bar stage 2 would be good.
Old Apr 28, 2011 | 06:48 AM
  #165
sujo's Avatar
I have left over pump and tank from my old Meth setup on my Camaro - just gonna order more hose/checkvalve/4 port manifold/ injectors and run it that way. If it breaks just means I need to build it sooner
Old Apr 28, 2011 | 03:35 PM
  #166
siadam's Avatar
Originally Posted by siadam
I'm doing the CM checkvalve tomorrow, I'll let you guys know how it works, or doesn't I guess.
See thread: https://www.s2ki.com/s2000/topic/863...0whp-500ftlbs/
Nik2k
Jul 22, 2014 06:36 PM
Bass
Feb 3, 2008 11:06 AM
S2ky0118
Dec 23, 2006 02:07 PM
JoeD
Jul 28, 2002 05:19 PM
