Direct Port Methanol Injection Setup
Old Feb 11, 2011 | 02:42 PM
  #61
EternalLx's Avatar
Joey you need those fittings the 1/4 fitting means its for the 1/4 size meth hose. the thread is 1/8 yes
just email coolingmist with your order number and he'll add it for you and charge your CC.
Old Feb 11, 2011 | 07:46 PM
  #62
siadam's Avatar
Originally Posted by JoeyBalls,Feb 11 2011, 03:36 PM
I ordered the 180cc injectors. It had an option for adding the fittings, but I declined, I think I need the other 1/8 fittings?
Is that all you ordered?
You need the jet's, the 90 degree elbows, the fittings for the elbows, the distribution block w/the fittings.
I didn't feel comfortable running the aem controller w/a direct port imo. Your gauge doesn't have failsafes for under/over flow if a line breaks or is clogged.
Old Feb 11, 2011 | 07:47 PM
  #63
siadam's Avatar
Originally Posted by s2000Junky,Feb 11 2011, 01:08 PM
This is correct.
I assume flipping it upside down would achieve what is desired - assuming the arm will indeed float up when there is fluid present.
I'm going to look @ this tomorrow, and I'll post back w/the results.
Old Feb 11, 2011 | 10:48 PM
  #64
EternalLx's Avatar
the 180cc comes with the 90 degree elbow
Old Feb 12, 2011 | 05:39 AM
  #65
JoeyBalls's Avatar
^ great, but I do need to order the fittings right?
Old Feb 12, 2011 | 08:23 AM
  #66
EternalLx's Avatar
yes
Old Feb 12, 2011 | 08:48 PM
  #67
siadam's Avatar
Originally Posted by EternalLx,Feb 11 2011, 10:18 AM
You sure you cant just flip the aem switch around?
Would be easier to get confirmation from you instead of me having to unbolt it from my truck
I looked this over today, pulled my tank and rotated the float. It only bends one direction, so w/it rotated 180, it is straight, and I think when you would fill it, it would actually move the float up, and trigger the fault.
So I am going to leave it, and just put the one they sent me in the bottom. I'll have 2 floats in the tank, but only one will be functional.
Just an fyi,
Old Feb 12, 2011 | 09:58 PM
  #68
EternalLx's Avatar
No that would be perfect, like I said in its normally clocked position; which is full tank = straight position; that triggers the low level on the CMGS. Now that you've clocked it when the tank is full the switch will float up and open the circuit which the CMGS will recognize as full tank so low level wouldnt be triggered.
Old Feb 13, 2011 | 10:47 AM
  #69
siadam's Avatar
In theory, I hope to have it wired up sometime this week, not sure though. I am loosing a couple days this week do to Valentines day, lol.
Old Feb 13, 2011 | 04:54 PM
  #70
JoeyBalls's Avatar
[QUOTE=siadam,Feb 11 2011, 08:46 PM] Is that all you ordered?
I didn't
