DIY Beadroller
Old Apr 12, 2011 | 05:37 AM
siadam's Avatar
Default DIY Beadroller
I bought some aluminum pipe that came with the ends bead rolled, big help btw.
Well, if you have to cut an end off, and don't have easy access to a bead roller or tig welder, you can use this easy trick.
As you can see the right side has the factory rolled bead, and the bottom is where I cut it.
I had seen this done years ago, but my cousin reminded me about it just the other day. A cheap harbor freight bead roller is still like $99 dollars, and most decent tig welders will charge ~$50/hr so this comes in as a very inexpensive solution.
I bought a set of vice grips @ harbor fright for $2.99
A 3" muffler clamp (sized per your piping dimensions) @ Auto Zone/Advanced for $2.99
Old washer laying around $Free
I first off I cleaned and prepped the vice grips to weld the muffler clamp to one of the jaw sides. I then tried to use the U bolt as a press on the bottom side of the other jaw, however, it proved to be to much to press into and I had to cut it down and weld on a washer. Which is the way I saw everyone else do it online, and now I see why, lol.
Finished product below.
My bead is on the right, with the factory bead on the left.
Entire project took me 20 mins maybe.
Overall, for a total cost of $6.00 bucks and similar results to a "real" beadroller, I am very satisfied.
Old Apr 12, 2011 | 06:05 AM
passmans2kny's Avatar
nice work
Old Apr 12, 2011 | 06:20 AM
GuardsRed's Avatar
cool trick, but this probably would only work for thinner walled aluminum.
Old Apr 12, 2011 | 07:27 AM
siadam's Avatar
Agreed.
Old Apr 12, 2011 | 09:29 AM
Torque Obsessed's Avatar
Very nice. I'll have to try this sometime.
Old Apr 16, 2011 | 05:42 PM
herecomesboost's Avatar
Old Apr 17, 2011 | 06:08 AM
pwrofdrm's Avatar
Wait, I don't see or understand what you actually did here...can you break it down for me? I've never seen this before but I could definitely benefit from it.
Thx!
Old Apr 17, 2011 | 03:21 PM
seoul2k's Avatar
wish i would have known this before i put all my chargepipes together and my bumper back on.... nice job
Old Apr 19, 2011 | 09:52 AM
siadam's Avatar
Thx!
What don't you understand?
Luke530
Jun 30, 2013 02:23 AM
jpetch05
Feb 4, 2012 11:17 PM
TubeDriver
Dec 7, 2007 06:10 AM
S2KPUDDYDAD
May 29, 2007 01:05 PM
