DIY Tuning for the AEM EMS Series II
Old Apr 24, 2012 | 09:11 AM
siadam's Avatar
Great info.
Old Apr 25, 2012 | 10:58 AM
indi00's Avatar
Update for youtube video for startup / idle tuning.
Somehow I can't embed the video.
Old Apr 25, 2012 | 08:45 PM
indi00's Avatar
Videos of tuning the N/A section of the map loaded
Old Apr 28, 2012 | 04:54 PM
indi00's Avatar
Some more updates...
Old May 8, 2012 | 06:42 AM
speedjunky01's Avatar
I like this thread a lot, good info and am hopeful it will get me to a supercharger basemap soon
Old May 18, 2012 | 06:45 AM
bobonacus's Avatar
Great write up , have just used it to create a new base map as I'm going to start from scratch again for my rebuild (uprating the s/c from 10psi to 18psi, rebore with 9:1 pistons)
A query about changing the injectors .... would you not use the change injector flow wizzard first so the fuel table is rescaled to the new injectors?
A couple of very minor points ...
You can copy and paste load points into the Load Breakpoints table if required
Typo - "Go back and high light the 3.9Psi Load row from 4500 to 11000 and subtract 4psi" <-- should just be 4
It's a little unclear what you are subtracting from the timing map over 7psi ... I can see from the numbers easily enough though
It's also worth noting that you need to be careful changing the O2 rich / lean limits as I've noticed AEMTuner sometimes drops the minus sign
Cheers
Robert
Old May 18, 2012 | 08:03 AM
indi00's Avatar
I didn't know about the wizard \change injector/flowpressure option. It scales the fuel table correctly.
The fuel table values will be tuned based on O2 feedback. I'm more concern about getting the ignition values transferred over to the new base map. Can't tune ignition timing on the street. One assumption I made is there is one degree of retard per pound of boost. Example, at 10psi, I subtracted a timing of 10 from the 0 LOAD (PSIG) row, which is 23.4. So timing at 10 LOAD (PSIG) is ~13.4. This value is used to get street tuning started safely.
In summary, ignition timing under 0 LOAD(PSIG) is based off the AEM basemap. Ignition timing > 0 LOAD (PSIG) is tuned with the assumption that MBT is knock limited, therefore optimial/safe ignition timing = < 2.0 knock volts under boost.
Be Safe.
Old May 18, 2012 | 08:27 AM
bobonacus's Avatar
Be Safe.
Ahh, yeah, obvious now
Old Jun 4, 2012 | 07:48 PM
the aem web app is down not sure how to go about converting the tables for more resolution now
any ideas?
Old Jun 4, 2012 | 08:02 PM
indi00's Avatar
scroll down to the bottom of the first post. http://forum.aempower.com/forum/inde...c,23845.0.html
D/L mapscaler.zip Read the readme files. Takes some massaging to get it to work. I've done it before, but the webapp was the easiest to use.
