Does a Comptech SC KIt feel fast?
Originally Posted by 2003s2k2003,Nov 22 2009, 08:00 PM
Sweet thanks man. I think then if I just ditch my gears get maybe 700 plus a stock diff for it, with that many can get some injectors pulley and belt and a little extra to go towards an emanage. Unfortunately I am sure I will need a clutch right away with that high boost though.
12 psi should give pretty decent gains lower down I would think then. 6-7 psi at 5k would be awesome!!
Also when you do upgrade the clutch make sure you get a 8-9lbs flywheel like a Findanza, if you want to liven up your motor throughout the entire rpm range. Well worth it.
Yeah I think I will try to not shift too hard when sc'd with stock clutch. Don't want to completely fry it until I have a clutch in hand and money to get it installed put aside.
Yeah I read that about AP1 clutches holding better so thats a good thing.
Is the flywheel really that big of a difference since the AP1 flywheel is already pretty light?
I had an 8 lb one on my dsm and it was definitely a nice upgrade but stock one was like 20 lbs so a much bigger difference there.
Made it almost want to stall out sometimes it seemed though. Same thing in the S?
A light flywheel also increases clutch effectiveness, adds life and more holding capacity under shifting or varied throttle applications. It takes less effort for your clutch to grab/clamp and hold 8lbs of spinning inertia vs 14 or 22.
Yeah I guess I might as well when in there do it.
the lighter flywheel makes it feel like less power down low though correct? The heavier it it I think gives the feel of more torque starting out.
Do you have a Fidanza flywheel on yours?
Also I think I remember that adding the sc on the car increases vibrations a lot. Forgot about this. Is that true at all? If yes would stiffer motor mounts solve that issue or just have to live with it?
Originally Posted by Lucky7s,Jun 3 2008, 07:47 AM
Unless you are talking about the Kraftwerks kit. It is linear because of the drive system being able to basically a turbo that is matched to the S2K properly.
This is the High boost dyno plotted vs. Boost (green line)
I think it is what makes it better than other kits out on the market as well as being able to just use the stock computer reflashed and bigger injectors and off you go.
If you have a 2005 or older S2K the kit for those will be released in the near future per Kraftwerks, *I know this is a bit of a shameless plug but it does show that there is a linear kit out on the market which is why I posted it*
Ok yeah I know that it frees up power with the lighter flywheel, but it feels like you lose low end torque from a stop with the lighter flywheel is I guess what I meant. Thats how it felt in my dsm with 8 lb flywheel at least.
Think about all the driving situations you get in, from starting out from a stop, stepping on the gas once your moving, driving up a hill, down a hill etc and ask yourself which one of these driving situations fits with the 2 things I mentioned above. Starting form a stop would be the second one for example, because this is what your car in a stopped position is trying to do, slow your motor down.
Ok yeah. I think whenever I do the clutch might as well put a lightweight flywheel in as well. No extra labor to do it then and should be a nice match with such a rev happy car.
