Does a Comptech SC KIt feel fast?
Originally Posted by 2003s2k2003,Nov 22 2009, 06:26 PM
Yeah pissed I just sold my vafc with plug and play harness lol.
Oh well will get an emanage or aem ems at some point when I up the boost and all anyways.
Originally Posted by 2003s2k2003,Nov 22 2009, 03:09 PM
Well a year later finally getting a vortech supercharger haha. Gonna keep the 4.77's too. I think this combo will be what I have been looking for for a while now!!
The short gears you think will make it slower on highway pulls really?
I would at some point maybe go to a longer gear especially when I upgrade the pulley but this diff has new gears and all in it which have only been used by me so no launches or anything so wold hate to get someone else's use diff and have no idea how they treated it.
Yeah I had the vafc 1 and just sold it with plug and play harness for $200. Oh well I am sure an emanage or something similar will be more effective and could even be used when I upgrade the pulley I would think.
4.30/4.44's are the best compromise from N/A to a boosted car up to about 350whp. I run stock 4.10 but have a lower pro 245/35/17 ive run since I was N/A and at 350whp its really as much gear as I would want to run at this point. First gear is useless from a traction standpoint, as it revs so fast it just spins so that hurts my acceleration, second gear spins at vtec on through redline if I don't baby it so i'm not going anywhere there, the point though is that even if you weren't spinning, your revving the engine quicker but the power isn't getting to the wheels as effectively, you could pull a trailer up a hill allot better though haha. When you downshift to get in the sweet spot on a high geared 4.56/4.77 buy the time you stab the throttle you need to shift again, you lunge 20' and you got to grab another gear and so on, its a crappy way to gain acceleration rather then letting your motor pull you. I dont know if this makes sense or not, you just have to try it to know i guess like anything. I can hear the debates coming already, but debates usually happen when people don't experience both sides.
Yeah that makes sense. NA I love the 4.77 gears and couldn't imagine being NA without them. Drove a stock geared s recently and felt so weak in acceleration in comparison.
1st gear already goes by super quick so I can see how that will be crazy with boost.
I think I will keep them at least until I upgrade the pulley and all.
At the same time as going through the gear quicker, wouldn't it help being up in the rpm range quicker since the higher the rpm the more power? Or does it just hurt since you get there but are out of the power quicker than with stock gears or longer ones?
Yeah I just hate the bog down feel of pre vtec with stock gears.
How much boost are you making low in the rpm range at 350whp?
It still builds a little boost even down around 3k right?
I would gladly ditch the gears if running higher boost would allow a little more boost down low to help out off the line without launching the car.
Would also help get some cash into my wallet for some other supporting mods and could probably just go straight to higher boost set up.
2k .5 psi
3k 1.5psi
4k 4psi
5k 5psi
6k 6.5psi
7k 8psi
8k 9psi
9k 10psi
Sweet thanks man. I think then if I just ditch my gears get maybe 700 plus a stock diff for it, with that many can get some injectors pulley and belt and a little extra to go towards an emanage. Unfortunately I am sure I will need a clutch right away with that high boost though.
12 psi should give pretty decent gains lower down I would think then. 6-7 psi at 5k would be awesome!!
