Does a SC require a break in?
The correct interval for tightening the belt is when the belt stretches to slipping it needs to be tightened. I have found belts slipping badly after 50 to 100 miles. I have ended up tightening them two, three even 4 times before they stop stretching. Tightening the belt on a Comptech is a quick proceedure. The Vortech takes a little longer. If you leave the plastic bottom aero piece off the Vortech adjustment goes much quicker.
its raining tomm hmmm man........
I would just check the fittings for any leaks, and check the belt.
