Does summer temps causing overboost?
Old Jun 28, 2011 | 06:35 AM
Nyther's Avatar
Default Does summer temps causing overboost?
My greddy turbo runs normally at 10.5 psi,
But now with the wheater increased from 20-35degrees celcius its overboosting to 13psi at just 4-5k rpms... What causes this?
I have a ported IG and a 3" berk headerback with HFC...
Im confused!
Old Jun 28, 2011 | 06:38 AM
Suzuka_Joe's Avatar
Colder air is also denser so your boost should increase in the winter. There is something else causing your boost to rise.
Check your wastegate and your boost controller
Old Jun 28, 2011 | 09:41 AM
Nyther's Avatar
After some heavy rain, things cooled down alot so i took another drive, this time it was holding the normal 10.5psi and went only slightly to 11.5 psi... weird...
I did noticed when installing the external wastegate, that i realy needed to pull on the actuator arm to slide it over the wastegate flapper... Perhaps there is too much tension causing overboost?
Perhaps i could unclip the actuator arm, adjust it so it slides easily over the wastegate flapper and then turn it 3.5 turns tighter... I think this should lower my overall boost IF there is too much tension on the actuator arm...
But i'm gussing i need to ask this in the GReddy topics...
Thanks for looking anyhow!
Old Jun 28, 2011 | 10:19 AM
Soul Coughing's Avatar
check vacuum lines and your wastegate, as you shouldn't have overboosting issues due to the increased temperature.
Old Jun 28, 2011 | 10:55 AM
S2000_FUN's Avatar
Old Jun 28, 2011 | 01:54 PM
Nyther's Avatar
I did checked the vacuum line going to the wastegate and it was in top shape... If i pull the turbo of the header, what symptoms do i need to look like to investigate the wastegate? Its only a flapper controlled by the actuator arm.. I don"t think the flapper is seized since its not overboosting badly..
Ill try adjusting the actuator arm after i checked everything.. I think that giving it less tension should lower the boost also?
Thanks for the help!!
BrockB
Nov 20, 2010 04:29 PM
g352s2k
Sep 6, 2009 04:27 PM
blueap2
Aug 26, 2009 06:56 PM
sbrodacz
May 10, 2009 12:49 PM
mr_grand_prix
Dec 21, 2007 04:46 PM
