Greddy Turbo
Old Sep 5, 2009 | 11:22 AM
g352s2k's Avatar
Arrow Greddy Turbo
Ok first problem, when I put the kit on at the beginning of summer. I had trouble with the boost tapering off towards redline.
Did a bunch of tests found out the manifold just needs to be tightened.. Problem fixed.
Next problem:
When getting on it the boost builds like a supercharger going from 7-10psi it felt fast and fun but not right. Drove it the next day now the boost stays at like 7psi but holds all the way through but i can't turn the boost up. I have an AEM Tru boost. For me 30-35% duty cycle is 10psi. I did turn it all the way up to 50% duty cycle and it hit 9psi then drops back down to 7ish psi and holds to redline. Do I need to check again for a boost leak or something? Sorry new o this stuff and its all ready pissing me off.
I really need some input on this and hopefully I can find out whats wrong.
-Qua
Old Sep 6, 2009 | 03:22 AM
asukadc's Avatar
how was the weather? i noticed when the outside temp 75 f or 85 f it loses .5 psi ish, then just set ur boost controller lil higher
Old Sep 6, 2009 | 04:23 AM
Revenge's Avatar
Not sure if this a greddy question on a boost controller question. Weather does make the car feel way different but seems like the car is running off the WG and needs more gain
Old Sep 6, 2009 | 08:24 AM
g352s2k's Avatar
Sorry guys im a dumbass we switched the solonoid tubes around for some reason and I just switched them back bc port 2 goes into the wastegate and I had it switched around. Im at 45% and at around 9psi now.
Old Sep 6, 2009 | 10:41 AM
jari8378's Avatar
^^ most of us have been there, its ok... im glad you fixed it.
Old Sep 6, 2009 | 04:27 PM
g352s2k's Avatar
Yeah I think the main problem was the manifold needed to be tightened and tubes switched around. Thanks for the input guys never fails for help on this site.
Nyther
Jun 28, 2011 01:54 PM
sbrodacz
May 10, 2009 12:49 PM
RichV
Aug 26, 2008 06:49 PM
mr_grand_prix
Dec 21, 2007 04:46 PM
Spec_Ops2087
May 5, 2007 08:57 AM
