dyno on 3rd/4th gear?
Old 08-20-2006, 09:17 AM
d.h
d.h's Avatar
Default dyno on 3rd/4th gear?
I know for a fact that when we dyno our car, 4th gear will show a higher hp than 3rd gear. But when I asked around, I was told that even though the dyno show 10 or more hp on 4th gear, it is actually unrealistic hp (fake hp). Can someone explain to me what that means?
Old 08-20-2006, 10:02 AM
Dsgs2k3's Avatar
i actually got more hp in 3rd gear. that shows you that all dynos are calibrated different.
Old 08-20-2006, 10:16 AM
Chris Macellaro's Avatar
Hello friend I assume you are talking about an inertia dyno...
Here is one example of a 248 Dynojet and how it works, this will give you a better understanding of why changing gear ratios will yield different results.
A Dynojet 248 is an inertia dyno
A Dynojet 248 is an accelerometer and here is how it works (calculation to optain HP reading)...
Force = Mass X Acceleration
Mass is the known roller weight
Acceleration is a change in velocity over a period of time
Acceleration = Distance divided by Time
exp. known roller weight X a change in velocity of 50 mph over 7 seconds.
A dynojet can only measures power output with a change in velocity. It can only measure power constantly at Wide Open Throttle.
So with the above being said if you change the gear ratio that the car is ran in it will alter the amount of time that the car physically takes to accelerate. Thus changing the output as calculated by the dyno due to different acceleration rates.
To answer your question an inertia dyno is normally run with the car in a 1:1 ratio. The reason being is that there is no mechanical leverage or lack of with overdrive (maybe a little to over simplified) to change the rate of acceleration. If the car is run in another gear other than 1:1 (4th gear in most transmissions) then you will have skewed results.
Note: This does not hold true with all dynos just dynameters that use this inertia based calculation method.
Chris Macellaro
Old 08-20-2006, 07:01 PM
gomarlins3's Avatar
I was about 8 hp better in 4th than 3rd and 5 hp better in 4th than 5th.
Old 08-21-2006, 06:25 PM
mase1's Avatar
In simple terms, Mr. Macellaro is trying to say that you get different results due to different amounts of load on the motor....
Old 08-22-2006, 05:19 PM
d.h
d.h's Avatar
I kind of understand that to get the most accurate HP reading, you have to match the ratio as close as 1:1 as possible. But in plain words, what does the extra HP mean when tested on the "no so" 1:1 ration?
Old 08-23-2006, 01:43 PM
timg's Avatar
Here was a comparison of 4th gear and 5th gear on my S2000. 5th has more torque, 4th has more horsepower.
Tim
SLINKYDOG
04-24-2010 02:46 PM
plastic91
05-18-2009 09:36 AM
Hiroprotaganist
05-23-2002 10:59 AM
BAD S2K
03-09-2002 06:25 PM
Shamu
11-09-2001 08:57 PM
Quick Reply: dyno on 3rd/4th gear?
