Dyno of S2Karts Modded Greddy
Old Feb 7, 2008 | 07:31 AM
HMFIC's Avatar
Originally Posted by S2Kart,Feb 6 2008, 09:29 PM
The numbers are corrected. I keep the water/meth in the washer fluid container.
i was just gonna recommend that if you didnt already.
Also, are you on stock HG? because if you lower that compression and raise the boost, you'll definately make ALOT more hp.
Old Feb 7, 2008 | 09:20 AM
S2Kart's Avatar
Originally Posted by SOHCmyDOHC,Feb 7 2008, 07:35 AM
I meant base map HP figures! My bad on the lingo
I don't have any power numbers when I was running the original map, but I'd guess it was around 290 with the stock cat. The Berk high-flow cat made a noticeable difference, and the WI injection + added timing was a big power bump. There should be another 10whp or so once I get the AFR down in the 11.8 range above 6500rpm.
Old Feb 7, 2008 | 09:29 AM
S2Kart's Avatar
I'm on the stock HG now. I might put in a 3mm HG later on, and would also need larger injectors.
To be honest though, I really don't want much more power, if any. The car is strong from 3800 rpm on up. I'd guess its capable of mid 12s with decent driving. I know an s2k at 330whp did 12.6 @108, and another at 340whp pulled a 12.2 .
Old Feb 9, 2008 | 10:28 AM
S2Kart's Avatar
Someone asked how much $$ I've spent:
$3900 Kit
$225 Berk cat
$200 AEM Tru-Boost (also a boost gauge, shows peak boost value on-the-fly, and you have a second boost setting by pushing a button)
$130 meth/water injection
$4455
Added 126 WHP, $35/hp
Old Feb 9, 2008 | 10:35 AM
qsmarcei's Avatar
Why is the dyno curve so wild ? Up and down? Is this normal? You can feel that in your driving correct?
Old Feb 9, 2008 | 10:51 AM
360glitch's Avatar
$3900 Kit
$225 Berk cat
$4455
The Tru-Boost system is great. That's what I'm running on my Camry. Once I get my hands on an S2K I'm sure it'll be a while before I go FI on it, but I think I would definitely like to do so one day.
Old Feb 9, 2008 | 11:33 AM
TRBOKEV's Avatar
Which water/meth injection kit are you running?
Good numbers, it must be a lot of fun to drive.
Old Feb 9, 2008 | 01:06 PM
joes sled 2000's Avatar
Very nice ! I sure wish my vortech power curve looked like yours !
Old Feb 9, 2008 | 01:40 PM
Yale972's Avatar
what kind of exhaust are you using?
Old Feb 9, 2008 | 05:37 PM
passmans2kny's Avatar
wow pretty impressive for the greddy kit, hope u hit 370
